First post, by Pingaloka
- Member
Hi guys, I'm putting up a Socket 7 machine and have a couple of questions.
Just want to get your different opinions.
First the processor, I'm doubting between a Pentium 120mhz or a Pentium 166MMX.
I want this computer to be my daily Dos game based machine. So ideally I want it to cover from 1989 up to 1996-1997ish...if I could play Blood at 640x680 res that would be magnificent.
My choice was a Pentium 133 because it can be slowed down nicely with L1 and L2 disabled caches. As I don't have a 133 CPU I thought about overclocking the 120mhz up to 133mhz. Is not a big difference, so I don't think I would made the computer unstable. BTW, do you guys think it would be necessary to change voltage just for 13mhz?
Another option would be putting the 166MMX, but from the info I gathered around, MMX's are the CPU's with less slow down. And in this case slowness is something we want to achieve.
Keep in mind this is an AT Socket 7 board. I'm not thinking about ATX or Super Socket 7, as I would have chose a AMD K6 II or something on that line
The other question is about what Graphic card I should choose. .
I thought of pairing a 2d Card with a Voodoo1. I have 3 options:
a) S3 Trio64+ 2mb
b) S3 Virge 2mb
c) Matrox Mystique 8mb
For compatibility I know S3 based cards are superior that the Matrox one, and to be honest I don't think I'll notice any difference in quality at low resolutions between these 3. Actually I have already tried the all of them, and didn't notice any difference in cuality.
BTW this will be a DOS only computer, no Windows.
I don't know the Board I'm using yet as it will be arriving tomorrow. I only know that it has a PS2 Mouse port, which is quite important.
I'll post some pictures when I get it.
