First post, by Moleculor
Ok, apparently something between .60 and .61 changed the way mounting CD drives has changed.
I'm using the same mounting method I've been using since something like 0.57 (namely with "mount e E:\ -t cdrom" and "mount f F:\ -t cdrom") and it worked all the way up to 0.60.
Now, with 0.61 (and a new OS... upgraded from ME to XP, if that makes any difference at all), when I mount drives, it behaves normally, and I can access those drives by typing E: and F: respectively, but when I try to run Millenium (a game that has successfully read the CD in the past in DosBox... sure, it promptly crashed afterwards, but it still read the CD)
Now the game just says that it can't find the CD.
Now, I've already tried reinstalling the game, putting it into the other drive, such things as that... Nada. And this is the -only- game this does this on... Another game, Fragile Allegiance, now works WONDERFULLY in DosBox (and the angels sing AAAAAAAAAAALLELUIA!), 'cept for no mouse detection (so I just have to hit Ctrl+F10), and it never has before, so I'm a happy camper... Just wondered if anyone out there had some tips for this other game.
