First post, by Half-Saint
Hi all,
this is my first post so let me introduce myself. I'm a computer enthusiast from Slovenia who only recently revived his interest in old PCs. Before that, I was mostly collecting non-PC computers and consoles from the 80s and 90s (Sinclair, Commodore, Atari,...). Here's my most recent project:
Specs:
Intel Pentium 120 MHz
Socket 7 motherboard VX chipset
64 MB EDO RAM
1.2 GB hard drive
Diamond Fire GL 1000 Pro
Creative Sound Blaster AWE32 CT3670
Pioneer DVD-106S/2 slot loading DVD-ROM
3.5" floppy drive
runs Windows 98
List of modifications:
First thing I had to do was clean everything, then I removed the power supply and cleaned it inside and out. Sleeving the cables was quite time consuming but it turned out better than expected. I didn't like the cable clutter so I ended up sleeving one IDE cable which was first cut in 8-wire strips. I also sleeved the PSU fan cable and replaced the original fan with a tri-color LED fan.
The attachment napajalnik_AT.jpg is no longer available
The attachment before_after.jpg is no longer available
The project is not finished yet. I will be sleeving all the internal serial/parallel cables and a 5.25" floppy at a later time.
The finished computer will be used as a working exhibit in my computer repair shop 😀
Cheers
SainT
Reply 1 of 7, by Private_Ops
Looks like a good start.
Reply 2 of 7, by LunarG
Sounds like that's going to be a nice system. I used to have a Pentium 120 back in the days. Blew one of my friends away when he saw Duke3D running on it (he thought I was still sporting my old 486sx33). All in all I think it's a great cpu for old dos games. Grats on a nice system. 😀
WinXP : PIII 1.4GHz, 512MB RAM, 73GB SCSI HDD, Matrox Parhelia, SB Audigy 2.
Win98se : K6-3+ 500MHz, 256MB RAM, 80GB HDD, Matrox Millennium G400 MAX, Voodoo 2, SW1000XG.
DOS6.22 : Intel DX4, 64MB RAM, 1.6GB HDD, Diamond Stealth64 DRAM, GUS 1MB, SB16.
Reply 4 of 7, by Half-Saint
Have you guys looked at the pix? Is it possible to use attachments so that they show up in the post as normal images?
2nd question: I'm thinking of adding a Voodoo 2 to the system. Will the Diamond card be good for that combo?
Reply 5 of 7, by LunarG
I can't imagine that there should be any problems with adding a Voodoo 2. Probably makes more sense using a Voodoo 1 for this era build though, but if you already have the Voodoo 2, then go for it 😀
Reply 7 of 7, by Half-Saint
vetz wrote:
LunarG is spot on.
Just be careful that the Voodoo2 is a bit larger and may not fit in all PCI slots on an AT board (depending on CPU position). On my Asus VX97 it is a tight fit between the card and the heatsink.
Thanks. I had to swap the cards around to get it right. Now everything fits perfectly 😁
