First post, by someperson42
I want to try to upgrade the hardware in one of my machines in order to increase performance. I have long suspected that Unreal's framerate is being hurt by my CPU, and I also do not like how this is affecting performance.
I have an Intel LT430TX board, currently running with a 233 MHz Pentium MMX. As far as I can tell, this is as good as it gets for this board, as it does not support the lower voltages required by the K6-2 and other faster Socket 7 chips. Am I correct?
Assuming this is correct, what type of board and CPU should I look for? The machine runs Windows 98, and is used for DOS and early Windows gaming.
