Alien Trilogy settings
First post, by MajorFoley
Hey guys ive used dosbox a bit back a few years ago when i wanted to play alien trilogy, seemed to work fine and ok but im installing on another computer and i do have a couple of questions. I installed it with the option of pentium and 16 colors
So the first problem is that sometimes the game decides to slow down a bit, mainly during combat for about a second then goes back to normal speed even with combat still initiated but it usually repeats itself and gets a bit annoying. another problem is with the fullscreen.
Whenever i fullscreen alien trilogy, the sound plays the but the screen remains black no matter what, it goes to main menu then switches to a demo and i can still hear the sound and that but the screen remains black
Right now im using it so it auto launches a config file
mount c c:\
C:\
mount d d:\ -t cdrom (i am using a retail disk so this command is needed)
cd c:\acclaim\trilogy
trilogy
pretty much this mounts the hard drive then mounts the cdrom then launches the exe
This works and lets me play in window mode ok.
Suggestions are welcome and will be appreciated
Reply 1 of 20, by Jolaes76
I have a vague memory of the game being buggy even beyond the final version.
Speedup issues are probably not exclusive to DosBox - I think I had them in DOS as well.
At least the color issues can be fixed with the patch (I have the EU version, you might have the US one). Double buffering, page flipping and palette issues are corrected for the most common VGA cards:
http://www.patches-scrolls.de/patch/298/19303
+ A very good walkthru:
http://thesandystamper.com/hiveseeker/index.html
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Reply 2 of 20, by MajorFoley
Jolaes76 wrote:
I have a vague memory of the game being buggy even beyond the final version. Speedup issues are probably not exclusive to DosBox […]
That doesnt solve the issue, the game runs fine to me and yeah ive patched using EU cos im using EU. i dont mind the slowing framerate sometimes its mainly the fact that i cannot go full screen but can still hear sound is whats annoying me and if i go out of full screen the game works fine
Reply 3 of 20, by eL_PuSHeR
Why is this topic on the PC section?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 20, by Jolaes76
Yes, it should be moved to DosBox, that is the platform.
Reply 5 of 20, by MajorFoley
oh uh, how would i do that?
Reply 6 of 20, by Jolaes76
...Earn some respect and become a moderator ? Nevermind, the mods will deal with it.
Reply 7 of 20, by MajorFoley
Well... my main pc can run alien trilogy in full screen. the problem now is the framerate is alot worse, jerky no matter what, tried all install options and patches, cycle max etc
Reply 8 of 20, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
Intel i7 5960X
8 GB DDR4 (2100)
Reply 9 of 20, by MajorFoley
Thanks for moving the post
on lighter news, i figured out the problem, it was my cd drive, for some reason thats whats slowing it down. Maybe because its a blu ray drive i dunno. Anyways i created an iso out of the disc i got and did a imgmount instead, and it worked a little too well. Now its extremely fast 🤣. Can anyone tell me how cycles work? apparently according to dosboxs compatibility list or something like that 30000 cycles should run the game smoothly, yet it runs at a jerky framerate for me. Anyways like i said this is working fine on the laptop when its on max cycles using auto. is there anyway i could pull the cycle value of that so that i can manually specify on the pc?
Reply 10 of 20, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You can adjust cycles on the fly and when you find the correct amount (ctrl+f11, ctrl+f12) put that in the conf file
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 11 of 20, by MajorFoley
oh yeah... guess i should try to match the speed im getting on the laptop, thanks for that
Reply 12 of 20, by IIGS_User
mount c c:\
C:\
Please run a "format c:" virus next. 😎
Klimawandel.
Reply 13 of 20, by MajorFoley
IIGS_User wrote:
mount c c:\
C:\
i know its safer to do straight to the folder, just eh. and yeah dont suggest that in a thread i was actually asking for help 🤣
Reply 14 of 20, by Dominus
DOSBox Moderator
You know, it takes about two minutes to make your dosbox more secure:
- make a folder in c:\ called dosgames
- move c:\acclaim into c:\dosgames
DONE!
Now you do almost exactly the same but instead of
mount c c:\
you do
mount c c:\dosgames
(I suggest you write that into the autoexec section of the config)
Reply 15 of 20, by MajorFoley
Dominus wrote:
You know, it takes about two minutes to make your dosbox more secure: - make a folder in c:\ called dosgames - move c:\acclaim i […]
DONE!
mount c c:\
you do
mount c c:\dosgames
eh ill just change it to c:\acclaim\trilogy,
i really only want to play one dos game and thats alien trilogy, and if i need to i can move it and probs play powerslave
Reply 17 of 20, by MajorFoley
Dominus wrote:
That might not work if the game stores where it was installed 😉
did when i tried it just gotta mount the cd or an image before i do it
Reply 18 of 20, by Dominus
DOSBox Moderator
Then it's cool 😉
(Some games won't like that though or might fool you until you want to save 😉)
Happy playing 😉
Reply 19 of 20, by IIGS_User
Me, too, happy playing, nice you saw my comment with sense of humour.
Klimawandel.
