First post, by robertmo
I thought that it would be better if dosbox.conf was arranged in this way (a more clear way):
[dosbox] \ the most frequently accesed options at the top
[cpu] \ (they affect compatibility)
[dos] /
[autoexec] /
[sdl] \ the look of the game
[render] /
[log] \ debugger
[debug] /
[mixer] \ sound
[midi] \
[sblaster] |
[gus] /
[speaker] /
[ipx] the rest
[modem]
[printer]
[bios]
I know I can change it myself which I did, but it may be also more clear for newbies
Reply 1 of 2, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
I do not like the idea to look for [autoexec] in the middle of the file (now it is at the end).
Mirek
Reply 2 of 2, by robertmo
it won't be in the middle, it will be on the first screen so you don't even have to press ctrl+end to access it 😀
but it may stay at the end as it is not that important for compatibility
