Reply 2620 of 59733, by Unknown_K
wrote:wrote:Bob can you tell me the name the Antec case went by so I can include those in my searches. Did Antec do them in beige also?
they sure did! i owned one, but later traded it in for the black. Also the front door is missing. this is the one I had for a LONG time: http://www.pcstats.com/articleview.cfm?articleID=1258
I have 2 cases with the somewhat the same layout (80MM cooling fan on top, 2 in the rear, 2 in the front, but also 2 on the side). Casetek made one and the other is a Thermaltake brand. The cases are beasts and I snagged them because they take ATX-E extended motherboards. The only difference I see is the HD section uses plastic rails and they mount toward the side panel.
http://www.hardwarelabs.de/bilder/projects/ca … setek_start.jpg
http://img.tomshardware.com/us/2003/02/11/15_ … ew/img_1075.jpg mines all black
