My K6-3 + Voodoo3
First post, by Automat
Hello friends!
I'm new in this forum, although i'm lurking now for a couple of weeks.
But instead of doing this, i'd like to introduce one of my estimated 15 - 20 Retro Rigs. The first here is now a really classic system, which i mostly like. Hope, you like it, too.
It is eqipped with the following parts:
Hardware:
K6-III 450, running with 500 MHz
DFI K6BV3+ 512 Kb, 4-way bank interleaving
128 MB SDRAM 2-2-2-5
Terratec Base 1 (german engineering... 😵 )
Maxtor 20 GB
LITEON CD-ROM LTN403 (40x CD-ROM)
RICOH CD-R/RW MP7083A (8x/8x/32x CD-RW)
3Com 3C90x Ethernet Adapter
150W psu
Software:
3dfx Tools
3DMark 99 Max
Adaptec Easy CD Creator 4
Adobe Acrobat 4.0
Base 1/64
BootUp 2000
Cachemanager
Command & Conquer Windows 95
CPUCooL
Forsaken
Mercedes-Benz Truck Racing
Microsoft NetMeeting 2.1
Microsoft Outlook 98
Need For Speed III
Need for Speed
PowerZip 4.5
Registry Optimizer
SiSoft Sandra 99 Standard
StarOffice 5.0
Tomb Raider - The Last Revelation
Tomb Raider Chronicles
Tweak UI
Unreal
WinTop
Symantec DiskDoctor 95, SpeedDisk 95, Systeminformation 95
and many more...
Reply 1 of 9, by LunarG
Nice system you got there. I've always had a soft spot for Terratec soundcards. I quite like the look of your case, nice and clean.
15-20 retro rigs you say? Wow, I'm envious 😁
WinXP : PIII 1.4GHz, 512MB RAM, 73GB SCSI HDD, Matrox Parhelia, SB Audigy 2.
Win98se : K6-3+ 500MHz, 256MB RAM, 80GB HDD, Matrox Millennium G400 MAX, Voodoo 2, SW1000XG.
DOS6.22 : Intel DX4, 64MB RAM, 1.6GB HDD, Diamond Stealth64 DRAM, GUS 1MB, SB16.
Reply 2 of 9, by stano
Nice system.
Always wanted a k6-3 system. At the time I went p3 and have many intel systems of that era. Still want a k6 however...maybe one day.
Reply 4 of 9, by Automat
Yes, a clean and smart system. And has enough power to play Unreal in XGA with full settings.
All parts, software and hardware, comply with the things build in 1999.
This K6-III is not an embedded, but an 2,4V cpu. It's the first one, that i saw, that runs stable with real 500 MHz.
The case contained a 486 system, but nothing special.
For the Terratec i searched a driver for only Win98SE. And found it. Win2k? WinMe? WinXP? Probably build in.
Reply 6 of 9, by Carrera
schön. 😀
Reply 7 of 9, by alex_ncfc
Always wanted a K6-3 years back for my JetWay 542C! Could never ever find one. Had to settle for a K6-2 500.
That is a nice case, but is that the floppy drive (where it says peacock)? I always used to try and avoid cases with a custom floppy drive bezel.
Wish I could find a nice looking and clean AT case though!!
CURRENT BUILD
Still using my 'retro'
AMD 64 X2 4200
3GB DDR400 RAM
400GB HARD DRIVE
WINDOWS 7
PNY GEFORCE 8800GT
ASUS A8N-SLI-DELUXE
Reply 8 of 9, by Nahkri
Is there a big difference in performance between the Via mvp3 and the Ali Alladin 5? I remeber that the Mvp3 was considered the faster chipset,while de Alladin 5 was more stable.
I,m thinking of replacing my Jetway 542C mb,which has Ali chipset,with 1 with Via.
Reply 9 of 9, by Automat
As far as i know from my own personal experience, the Ali is faster than the MVP, RAM throughput is some 30 - 40 % higher.
I think, the MVP is also a stable chipset, but is could be tricky to install the right (4in1) drivers in the right way.
