For dos games the radeon 7200 is just fine, the problem is with quake 2 and other windows games like tomb raider II.
http://www.anandtech.com/show/272/15 here's where I saw the frames per second. (but with a celeron 266MHz, I didn't find a score with a pentium mmx =/
And the problem with the older drivers is because I get a error :"video card inf not found" then a french mensage I think.
 Hmm I remember the omega drivers, I'll give it a try 😀
I'm using a pentium MMx 233MHz with 1mb l2 cache, 128mb sdram (pc100), 80gb ide hd, maxi sound game theater 64 sound card, agp2x,and the good and old ati radeon 7200 (I remember that gpu could easy do more than 100 fps at higher resolution at quake 2, but here it's only giving me 15 - 19 fps '-' [15fps with an older driver]).
The operational system is windows 98se.
 I would like to play windows game like tomb raider 2, need for speed II or III, quake 2, half life,... and even dos games (but for dos i wouldnt need to change the gpu since it works perfect).
EDIT:OPS now i noticed I typed it got 50 - 70 fps on a pentium mmx, but it was a celeron with 266MHz :s
EDIT2:The system was using 384mb of ram, but it looks like the 256mb memory is failing (The bios say it failed on the fast memory test)
