First post, by sndwv
I recently purchased a 16:10 monitor, and am experimenting with either stretching or 'pillarboxing' old DOS games in DOSBox. To attempt stretching, I have fullresolution=desktop (1920x1200), output=overlay, aspect=false and tried different scalers. I noticed low resolutions (SQ1-5, Dune 2 etc.) stretch to full width as expected, but svga resolutions (SQ6, Privateer 2 etc.) do not and remain 4:3 pillar boxed... is this simply not possible or am I overlooking a setting? Thanks!
Reply 2 of 7, by Great Hierophant
The best pillarboxing for 320x200 graphics is to have fullresolution=1600x1200, use output=direct3d (you need Yhkwong's SVN build), aspect=false and scalers=none.
The best stretching for 320x200 graphics is to have fullresolution=1920x1200, use output=openglnb, aspect=false and scalers=none.
Reply 3 of 7, by leileilol
I just use output=direct3d, fullresolution=desktop, aspect=true, scaler=normal2x, pixelshader=crt.d3d.br.fx....
Debian's fucked
Reply 4 of 7, by sndwv
Ok, thanks all. I've read through the posts and watched Mau1wurf's videos. Basically, I've got the pillar boxing covered now, but what if I wanted to run, say, Space Quest 6 stretched (non-aspect scaled) to fit the whole screen? I can achieve this by outputting a 4:3 resolution via DOSBox (1600x1200 on my 1920x1200 screen) and let either the video card or the monitor do the stretching, but both result in slightly softer edges. I still have not figured out how to let DOSBox do the scaling internally like it does with low resolutions like 320x200 output at 1920x1200. Or is this where I need output=direct3d and a patched DOSBox build?
Reply 5 of 7, by collector
Remember that SQ6 is a VESA game (640x480). It does not even ship with a VGA driver. Aspect correction will have no effect.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 6 of 7, by sndwv
Ah, thanks! That was indeed the bit of information I was missing; did not know non-aspect scaling only works for VGA.
