Hm, a little input from me.
As an owner of two notorious for their bad caps boards - the ECS K7S5A (which had two recaps up till now), and an Epox 8rda3+, my opinion is:
Never use desoldered (from another board) capacitors. (welll. if it's something expensive, or you cant find it ... but it's another story)
Aways get japanese capacitors for replacement. It doesn't matter (for me) if it's a Panasonic, Nichicon, Rubycon or anything else (japanese), but keep in mind the following characteristics:
- 105C
- Low ESR
- Life hours (they do differ for different series)
- Size !!! 😀 (diameter)
You could make compromises with capacitance and voltage - I usually replace 6.3V with higher voltage, cause I can't find 6.3 ones 😀 And I usually try to keep the capacitance, but when I recap my soundcards, for example, I put as big (size and thus capacitance) as possible. Don't know what's it in theory, but slightly bigger capacitance won't hurt the board (I tried on that K7S5A, when I hoped for more stable overclock - it's still working).
Get a dentist probe or something similar - stainless steel. Sometimes you can't vacuum all the soldering material from the hole (or probably my dealextreme's soldering vacuum pump is crappy). But you can heat, then gently put the dentist probe in (heat from the one side, put the probe from the opposite side), and when it's stainless steel, it won't get soldered - you can twist it, pull it out and have a nice little hole. Be carefull, though, cause there are tiny little copper rings in that holes - if you tear them out, you have to solder the capacitor straight on the line of the board (you have to clean the polish first).
Ah, and I'm a rude guy, so I desolder at max temp of my iron (450C) - haven't killed anything yet. I aim to heat the legs (and arround) of the capacitors. Do not use force (because of the tiny little copper rings) to pull them out - heat more, pull out gently.
Well, I think I already said too much, hope nobody gets bored 😀
