First post, by carlostex
Heya!!
For anyone who has a socketed EPROM with 1.00 Control ROM, i've found a suitable EEPROM to replace it. Winbonds W27E512 or W27C512 are pin compatible, with the usual Am27C512 EPROM that comes on older CM-32L reviosions with a Socketed ROM.
I just programmed the 1.02 control ROM and it is working great. EEPROMS are a less of a pain to erase, so i went with this instead of buying a new EPROM or erasing one.
Reply 1 of 11, by keropi
Great news!!!!
I was lucky to find some NOS AM27C512 uv eproms, but ofcourse eeproms are prefered! thanks for the info Carlos!
Reply 4 of 11, by carlostex
The 1.02 Rom solves a cliking issue:
http://queststudios.com/smf/index.php?topic=3564.0
To check, one needs to open his/her CM-32L and check if the unit has a socketed ROM or a soldered mask ROM on board. An EPROM on a Socket means you have Control ROM 1.00. The sticker on the EPROM has numbers that indicate exactly its ROM version.
Check this:
http://www.youtube.com/watch?v=5NUQpAZeAdo#
Reply 5 of 11, by keropi
easiest way is testing with TAKEGO.MID as described, I am attaching it for convenience
    TAKEGO.rar
    1.16 KiB
    187 downloads
    test midi
Reply 6 of 11, by Mau1wurf1977
bjt wrote:
Hi carlostex,
Would you be able to give us a quick rundown of the differences between the control ROMs and how to tell which version a particular CM-32L unit has?
Thanks
Alternatively you can send a special MIDI command the unit and it will send back the ROM version 😀
I believe I also covered this in my video. But not 100% sure.
The serial number is also a good indicator. Again watch my video as I have forgotten all the details already 😊
My YouTube channel
Reply 8 of 11, by ih8registrations
I looked to see if someone has tried doing a mt-32 to cm-32l rom upgrade, didn't find, but there are several mods.
http://www.oldcrows.net/~patchell/mt32/mt32.html
http://www.houseofsynth.com/roland-mt-32-hard … e-sound-quality
Reply 9 of 11, by Great Hierophant
I believe such a mod may be possible to turn a late MT-32 (with a headphone jack) into a CM-32L. It would require replacing the MT-32 Control ROM with the CM-32L Control ROM and the MT-32 PCM ROMs with CM-32L PCM ROMs. EPROMs may be used. I am not 100% sure, but I believe the late MT-32 only has one PCM ROM. The CM-32L increases the PCM ROM size from 512KB to 1MB, but uses two ROMs. The CM-64 schematic shows how the chip enables work with the LA32 chip, and you would need to replicate that circuit and piggyback the two ROMs.
Reply 10 of 11, by ih8registrations
I was thinking a good mod would be to connect a microcontroller with ram/sdhc/usb to the rom sockets to allow switching rom sets on the fly,
