Reply 2780 of 56719, by bestemor
Old Thrashbarg wrote:
It came equipped with an Asus P2-99B. Fukken sweet. 😎
Baby-AT Slot1 boards are really damn hard to find, and reputable brands even more so.
If you ever need a 'NEW' boxed/unused spare (or NINE...?) : http://www.ebay.com/itm/400504376709
('best offer' available...)
Reply 2781 of 56719, by thegardentool
schlang wrote:
bytesaber wrote:
Canopus Pure 3D
Found it on eBay. This is a 6MB version of a 3dfx Voodoo card. Most vendors used the standard 4MB. It came with the manual, driver CD, and the 9 pin VGA pass through cable. Also found the decal sitting in one of the pages of the manual!
would you mind measuring the canopus vga-loop cable pin connections? I don't have one anymore and it's the same kind of loop cable which also matches the miro hiscore 3d cards
Schlang, what exactly are you wanting measured? I've got one here that I got with my Pure3D a few weeks ago. Overall length is 18", cable length is 14.5".
Main: 7800X3D | X670e | 3090 | 4k144hz
Retro: Kind of together: P3 | ASUS P3B-F | Canopus Spectra 2500 | Canopus Pure3D II SLI | (sometimes a Voodoo 5 AGP) | SoundBlaster AWE32|
Reply 2782 of 56719, by PeterLI
Also got a MPU-UPC-T in the mail here in NY today. Works great in my 80286 Leading Technology AT5000 with my FB-01 and Silpheed.
Also got MS-DOS 6 Upgrade on 5.25" diskettes so I upgraded the same machine from 4.01 to 6.0. It has a 5.25" HD FDD as A: and 3.5" HD FDD as B:. I replaced the 5.25" HD FDD with a TEAC (I dislike round LEDs) and installed a 3.5" HD FDD as it came without one. That machine now has a MPU-IPC-T and CT1600. Only 1 ISA slot left: probably for a LAN card at some point. I just dread having BNC cables all over the place. I may have to go the route of a HUB with a BNC (to connect my PS/2 Model 30 8086) and then UTP the 16 / 32 bit machines. 😊
PS/2 Bear is now also part of the family! My oldest son likes him a lot already.
Reply 2783 of 56719, by Old Thrashbarg
There are plenty of ISA ethernet cards with RJ45 connectors, and I'm sure at least some of 'em will work with a 286. As for your PS/2, if it has an AUI connector, you could just use a 10Base-T media converter on it. Then you wouldn't have to screw with thinwire at all.
Reply 2784 of 56719, by SquallStrife
I use a 3Com 3C509B-TPO in my Tandy 1000, works a treat.
Someone on Vintage Computer Forum patched the packet driver so you can use it with 8088+ systems.
Reply 2785 of 56719, by Kahenraz
Crystal IPLS32-S23 / CS4232-KQ
Sound Blaster 16 CT2230 w/DSP
Sound Blaster 16 CT1790
Raspberry Pi GPIO extender Cable (midi header extension!)
BIOS upgrade on my Apollo chipset allows new P3 CPUs. Don't know to what speed so I bought all the high-end coppermines:
Intel Pentium III SL5QV (1GHZ/100) Coppermine
Intel Pentium III SL4C8 (1GHZ/133) Coppermine
Intel Pentium III SL5QJ (1.3GHZ/133) Coppermine-T
Reply 2786 of 56719, by PeterLI
The AUI / BNC transceivers / converters are pretty expensive. I will just go for a BNC / UTP HUB instead and hook up a 8 BIT LAN card with BNC. 😊
Reply 2787 of 56719, by Robin4
My last one.. Then i have enough off these SB2.0 card.. With this one i have 5 in total.. 4 are the good versions to use on CMS.. 1 is the bad version.. I think i just keep it as spare..
Then i can use two card for my V20 XT (think iam going te remove the CT-1350B this now in the system, i like this card but it doesnt have a input jacket) I need a imput jacket so i can bypass the sound from my roland MT-32 to this SB2.0 input.. Then i have two cards for V20 XT (one is spare) and got two for my 286-12mhz system build (one is also spare)
Reply 2788 of 56719, by PeterLI
Cool! Where do you find your equipment in NL?
Got an Everex Tempo 486/33C in yesterday evening. Pretty cool little machine. Slim line 5.25" HD FDD (that works). Installed a WD 210MB IDE HDD. Also installed a 3.5" HD FDD but need to get longer cable to support it. Replaced the Maxell 3.6V 1800MAH (dead: from 1991) with a Duracell 9V for the time being (tried 2 AAs but that did not work). 3.6V 1800MAH batteries are really expensive. The MOBO turns out to be a 80386 MOBO with a 80486 overdrive. It has 4MB RAM, 128KB cache and a i80486DX33. I installed a SB16 CT2230 ASP/CSP in it as well.
http://stason.org/TULARC/pc/motherboards/E/EV … ml#.UoTMK_nktCY
Reply 2789 of 56719, by Artex
Greetings everyone! Been a while since I last posted, and I've picked up some more goodies!
Motherboard - Gigabyte GA-5AX Super Socket 7 Rev. 5.2 (2000) **Nod to Mau1wurf1977**
Turtle Beach (Voyetra) Monego II Quadzilla (4-channel) (Aureal AU8830 Vortex 2) PCI (1999)
Turtle Beach (Voyetra) Montego DDL 7.1 PCI (Boxed) (2005)
Turtle Beach (Voyetra) Montego II with VoiceXPress PCI (Boxed) (2000)
Yamaha SW1000XG PCI (Boxed) (1998)
Aztech Sound Galaxy NX Pro IDE ISA (1993)
Aztech Sound Galaxy NX Pro SCSI (without VLSI Controller Chip) (Packard Bell OEM) ISA (1993)
Creative CT1770 (CT1779) (Sound Blaster 16 SCSI) Rev. 4.05 ISA (1993)
Creative CT4171 (Sound Blaster 16 WavEffects) ISA (NOS) (1997)
Media Vision Pro Audiospectrum 16 (650-0044-01) ISA (NOS) (1992)
Media Vision Pro AudioSpectrum Basic (650-0053) ISA (Boxed) (1992)
Misc - Band In a Box Version 9 with Roland Virtual Sound Canvas VSC-88H
Reply 2790 of 56719, by Old Thrashbarg
Turtle Beach (Voyetra) Montego DDL 7.1 (Aureal AU8820 Vortex) PCI (Boxed) (2005)
I think you got some details mixed up... that's not an Aureal Vortex card. It uses a C-media chip, and is pretty much unrelated to the 'old' Montego cards.
Reply 2791 of 56719, by Artex
Thanks! I pulled it from the WIKI.
http://en.wikipedia.org/wiki/Turtle_Beach_Systems
Reply 2792 of 56719, by PeterLI
Cool stuff 😀
Reply 2793 of 56719, by Old Thrashbarg
That Wiki article looks like it might be a case of somebody entering the right information in the wrong place. The Montego A3DXstream, which is listed immediately below the Montego DDL, is the AU8820-based card.
I think Turtle Beach Systems can also be partially blamed for having completely different cards with very similar names... 😒
Reply 2794 of 56719, by PeterLI
Thice thing about Wikipedia is that you can go in there and fix it. 😁
Reply 2795 of 56719, by Stojke
How much did you pay for the Yamaha SW1000XG?
And is Aztech Sound Galaxy NX Pro IDE ISA any good?
Reply 2796 of 56719, by Artex
$160 + $20 shipping to the US.
The Aztech Sound Galaxy NX Pro is a good alternative to the Sound Blaster/Sound Blaster Pro. It's got OPL3 (YMF262-M) + great compatibility (Adlib, Sound Blaster, Sound Blaster Pro, Disney Sound Source & Covox). They are generally better shielded and less noisy than the sound blaster cards. I think it was originally from Germany if I'm not mistaken...??
Reply 2797 of 56719, by sliderider
You're going to love that Quadzilla. I managed to find one a few months back after searching for a long time. It's good that you got the driver CD with it because the Turtle Beach A3D cards with quad stereo don't work with the standard driver. They require a unique driver that enables quad stereo and activates the S/PDIF. With the standard driver, they only work like a normal Montego II.
Reply 2798 of 56719, by Stojke
I ask because i am selling one boxed with cables and stuff for 100e 😁
Also thanks for info about Aztech. Saw one on the flea market.
Reply 2799 of 56719, by carlostex
Increasing my Super Socket 7 motherboard inventory:
This is quite an unknown one. Freetech/Flexus P5F103.
Had to remove BIOS chip and burn the BIOS upgrade manually. Now it supports K6 plus. 😎
