Reply 40 of 543, by Anonymous Coward
- l33t
I reproduced this modification on an M-Tech R418 486 motherboard with Award BIOS and Holtek KB controller. I believe I can get this working on boards using the AMI Hi-Flex BIOs as well. I will test this out tomorrow. It should be possible to get this mod going in systems that use BIOSes without mouse support as well. I think the BIOS is just sending a command to the KB controller, which we can probably do using a DOS TSR.
I will also start testing a few different KB controllers to see which ones have mouse support. I strongly suspect the AMI Model F does, which would be great as it is extremely common.
