ECS Elite UM8810PAIO REV:2.1
Reply 60 of 111, by JaNoZ
I wanted to have the VRM stay original, and this way i can mount in two different ways depending on how much room for me there is in the case.
And the VRM is much more easy to remove and change the voltage settings.
I have neither KBC, i think i have a WT62P2 IC see datasheet.
I think no ps2 support for me.
Reply 61 of 111, by feipoa
USB monitor controller? You sure that is the correct datasheet?
Reply 62 of 111, by JaNoZ
Probably The wrong one but i see no other sheets
Can it be an programmable universal serial com and converter processing ic?
Reply 63 of 111, by horstmueller
ok - success! working ps2 port on my board
Pinout is
Data
Clock
GND
NC
VC
-> Version 4 in my tryouts. Maybe I made a mistake when trying out all the possible pinouts. Anyway, now its fine.
... now I need some more Cache - only 128k is installed - any suggestions where to get it?
Reply 64 of 111, by feipoa
horstmueller - excellent!
Could you upload a photo of your motherboard? Does it have Phoenix or AMI BIOS? Could you upload the BIOS image? Is there a section in the CMOS to enable or disable the PS/2 mouse? This information may be of some assistance in helping us get PS/2 mice working on any AMI BIOS motherboard. We've already gotten it working on any AWARD BIOS motherboard.
Reply 65 of 111, by horstmueller
it is the latest phoenix bios i found for this board
PhoenixBios 4.04 PnP
-> V3.2j 12-11-96
Board Revision 2.1
no section to enable / disable ps2 mouse. It just gets detected at bootup
Photo comes later
... but currently there is the same revision on the german version of a well known online auction house with a picture ...
Reply 66 of 111, by feipoa
horstmueller, does the AMI BIOS for this board work with the PS/2 mouse?
Reply 67 of 111, by horstmueller
i did not try.
Reply 68 of 111, by feipoa
Are you willing to try? It would be most appreciated.
Reply 69 of 111, by horstmueller
if you can supply it, i will try. i have an external chip programmer.
Reply 70 of 111, by feipoa
This is what Janoz wrote,
I got myself a ecs um8810paio rev2.0 with amibios.
Janoz, could you provide the AMIBIOS for this board?
Reply 71 of 111, by feipoa
Anyone have the AMI or AWARD BIOS for this board to upload?
Reply 72 of 111, by Liqu1d82
Hello, I'm following with interest your discussion: just today I received the um8810paio rev. 2.0 and I did not know about this voltage regulator! Fortunately, along with the motherboard, the CPU is present, a Texas Instruments @80MHz, and the particular controller is present, model VR-102. I hope to try as soon as possible this configuration.
Without change something sleeps inside us, and seldom awakens. The sleeper must awaken.
http://liqu1d82.tumblr.com [My Tumblr] // https://twitter.com/Liqu1d82 [My Twitter]
Reply 73 of 111, by feipoa
What is the datecode on your chipset? Do you have AMI, Phoenix, or AWARD BIOS?
Reply 74 of 111, by Liqu1d82
BIOS is AWARD (with the label "Neue Version UM8810PAIO Ver.1.10PH), on the chipset I read:
UMC
UM8881F
RC1503
And:
UMC
UM8886F
9504-BS
RA0649
Reply 75 of 111, by JaNoZ
Please let us have a copy of the award bios we are in need of it very bad.
We only have award version 1.0 for this board and it is too old.
Reply 76 of 111, by Liqu1d82
Of course, I'll help the best I can - you have to have patience because I'm overwhelmed by my work (in this period I'm having more of it) - as soon as I start to work on it and test it I will help you! Does attached file is the utility to dump the bios?
Reply 77 of 111, by JaNoZ
The attached file is the 1.0 award bios version for the UM8810PAIO.
But i would like your 1.10 to add to my bios collection and i prefer to use some award bios instead of the phoenix that i have now.
You could dump the bios with uniflash.
Reply 78 of 111, by rgart
nice work getting your ps2 mouse working horstmueller. I destroyed my um8810 so I picked up another one that has the VR-102 voltage module. I have yet to test this board thoroughly again but I will get around to it .....
I never got SCSI working with the UM8810. It hated my two Adaptec AHA-2940U2W Ultra2-LVD (Bios v2.00.0) cards but the board itself was stable and fast.
=My Cyrix 5x86 systems : 120MHz vs 133MHz=. =My 486DX2-66MHz=
Reply 79 of 111, by JaNoZ
Rgart...
What did you do to destroy it.?
