Too much RAM for some games?
First post, by schlang
Hi, I'm having trouble running some games on my K6, like Crusader: No Remorse and Ultima 8.
Seems to be related to its memory, 512 are just too much.
Are there any feasable solutions? Eexcept for going down from 512 to 64MB...
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 1 of 29, by Jorpho
And what specifically leads you to that conclusion?
HIMEMX will let you restrict available memory, though I am not sure if it will work with those games specifically. You can also create a RAM drive to consume some of your available RAM.
Reply 2 of 29, by jwt27
If the game has trouble with too much free XMS, you could try filling it up with something useful, like UIDE.
If it's complaining about too much total memory, you'll need to "mask" a part of it with HimemX (=JemmEx).
Reply 3 of 29, by Mau1wurf1977
There is a good existing thread on this! Can't remember the name though 😀
My YouTube channel
Reply 4 of 29, by schlang
starting the game with command line parameter "-x 50" reveals a negative system memory value
I think this is what I need - how to? I checked the readme http://www.japheth.de/Jemm/README.html already
Reply 5 of 29, by jwt27
Check again 😉
 MAXEXT=l      limit extended memory controlled by XMM to <l> kB.
X2MAX=m limit for free extended memory in kB reported by XMS V2
(default 65535). It is reported that some old applications
need a value of <m>=32767.
But If I were you I'd try UIDE first, having a large disk cache provides a serious speed boost. Here is an example:
        REM /D: = CD device driver
REM /H = Load to HMA
REM /F = Use large (fast) cache blocks
REM /Sn = n MB cache
REM /Rn = Use memory above n MB
1?DEVICEHIGH=C:\DOS\BIN\UIDE.SYS /D:FDCD0001 /H /F /S128 /R63
Reply 6 of 29, by schlang
jwt27 wrote:
But If I were you I'd try UIDE first, having a large disk cache provides a serious speed boost. Here is an example: […]
works! excellent thx guys 😀
Reply 8 of 29, by sliderider
I find it ironic how games back then used to always be demanding more memory in order to run but then when you gave it to them they still wouldn't run because you gave them too much. 🤣
Reply 9 of 29, by Samir
I remember when we maxed out our 486dx66 with 32mb "just because". It was a total waste since it ran fine on 16mb.
Now fast forward and imagine the same programs trying to deal with 256mb of memory. 😵 They just didn't expect something like that.
I wonder how much the whole finackyness of memory changed after the first 1mb? Is it basically the same all the way up to 4gb?
Reply 10 of 29, by schlang
from a programatically point of view you can easily explain such things e.g. chosing the wrong datatype.
no one would expect that their games are still being played after 20 years 😀
Reply 11 of 29, by Jolaes76
What really interesting is that sometimes you DO need to physically reduce RAM size. (Because the game checks/adds up all you have in the system) Fortunately, EATXMS and similar utilities work in more than 90% of all cases. The above discussed RAM drives are more useful, of course. I also recall lighter issues when only the size of EMS is checked - here, you only have to restrict available EMS in the EMM386 command line.
Another funny thing is when games/apps check if the system has free base memory in a certain range (say, like between 590kb and 630kb). When you install a memory manager like QEMM and choose to beef up the conventional memory range (merge with UMBs?) to about 700Kb, these games/apps will bail out instantly 😵
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Reply 12 of 29, by Samir
Ah yes, quite true!
Reply 13 of 29, by Samir
QEMM always had some funky issues. It was really good prior to the advent of himem and emm386 in dos 6. Then you could achieve virtually the same thing using native DOS stuff. Although that merging feature of QEMM was way cool. 😎
Reply 14 of 29, by Mau1wurf1977
There is a reason I got 16MB SDRAM for my Super Socket 7 Time-machine system 😀
My YouTube channel
Reply 15 of 29, by Gamecollector
Well, my DOS PC use the MSDOS 6.22 himem.sys. It have 64 MB limit.
Reply 16 of 29, by schlang
EMS/XMS was not the problem here.
UIDE is indeed quite cool and solves two issues at once
Reply 17 of 29, by keropi
this has been discussed in depth in another thread, my solution for my ss7/128MB machine is xmsdsk/emsdsk , they are ramdisks that you can load/unload and they consume successfully the extra ram that causes trouble.
The /t switch they have is also valuable since it forces them to load above the first 16MB of ram, leaving it free for even more troublesome games. It can be easily used in batch files without limitations.
Find it attached, it solved my problems just fine.
    xmsdsk.zip
    73.73 KiB
    109 downloads
    XMSDSK EMSDSK ramdisk
Reply 18 of 29, by jwt27
Plus you'll get a "free" CD-ROM driver with it (costs only a few bytes) 😀
Reply 19 of 29, by Samir
I use the one from win98se and am able to get a lot higher than that.
Come to think of it though, we had 128MB in our old Cyrix system and it ran win3.1. And I know himem saw all 128MB. 😕
