What soundcards should I stick into a 486
First post, by bristlehog
I've got a 486 with three ISA slots on a riser, all of them support full-length cards. This PC has two CPUs: one soldered in 486 SX-25 and one Socket 1 which is currently filled with Kingston Turbochip (which is Am5x86-133 on a Socket 1 adapter).
I am unsure of what should I stick there. I currently have:
ATI Stereo F/X with CMS
SB 2.0 with CMS (however, that's a faulty revision one)
SB Pro 2 CT1600
SB16 CT1730
Vibra16 CT2940 CQM version
SB AWE32 CT2760
SB AWE32 CT3990
SB AWE64 Gold
Terratec EWS64XL (however, there's no place to stick its 5.25" front panel provided that I still want the CD drive)
Roland LAPC-I
GUS MAX 2.1
Orchid SoundWave 32 512K ROM version
Aztech SG NX Pro
Yamaha OPL3SA3
I currently have no daughterboards and no external modules (however, I think of buying a Yamaha FB-01 soon). I have both MCB-1 and Gravis MIDI adapter so I'll be able to use virtually any card I have to drive external MIDI modules.
I think that ATI SFX and SB 2.0 are way too ancient to stick into a 486. SB 2.0 is very noisy, so is Aztech SG NX Pro.
Terratec EWS64XL works here, but it has issues with PS/2 mouse (they fight for IRQ12) that I haven't been able to solve yet, and since this PC has no USB ports, it's a problem.
Orchid SW32 only has SB 2.0 support, no SB Pro. It does emulate a MT-32, but then I have a LAPC-I anyway.
What I want is DOS jukebox with many MIDI music options; of course, there should be a possibility to run majority of DOS games, however, I don't intend to play them since I have no time for that currently.
I thought of LAPC-I and GUS MAX and some SB card, maybe a 2760 if there's enough resources for them to live together. Thus I get: OPL3, MT-32, GUS, EMU8000... but no GM unless I buy an external module or a daughterboard for 2760. Anyway, for GM I only have SW32 whose GM is crappy, and a Terratec, who is a resource hog (or it's me who can't set it up well).
Any thoughts?
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
Reply 1 of 24, by Mau1wurf1977
What games are you going to play?
I'd go with the AWE64 GOLD unless you want to play really old, FM only, games.
But you might want to get an external Sound Canvas as well.
My YouTube channel
Reply 2 of 24, by bristlehog
I want an opportunity to run most of the games that have MIDI for music (including early titles which provide interesting music options like FB-01).
I've noticed that you're an AWE64 Gold fan. However, I don't like CQM much. Neither do I like issues with muted/garbled OPL part after EMU8000 usage; however, AWE32 cards suffer of that no less than AWE64.
Reply 3 of 24, by Mau1wurf1977
Well for MIDI you will need:
- MT-32 (Old)
- SC-55
You can use the LAPC-I to drive it all.
Or did you mean FM?
What I found about GUS, CMS, PAS is you spend time and money to source the cards, then listen to a few games but in the end you go back to Sound Blaster and Roland 😀
My YouTube channel
Reply 4 of 24, by bristlehog
I have a collection of XMIDI files (currently something about 2.5 thousands). Lots of them are meant to be played with OPL2/3, some are for GM, some for MT-32, and small number is designed particularly for GUS or AWE32. It would be great to play any of them without having to change hardware.
Reply 5 of 24, by badmojo
Ha, that's your answer to everything Mau1wurf! The AWE64 might be a good card but it's so boring 🤣
I'd say the CT1600 & the LAPC-I - a nice simple setup that will rock everthing this side of general midi. If GM is required then an external SC55 is the way to go, driven from your LAPC-I if you have that breakout box thing, and if not then just wait for Bjt to upgrade softMPU to allow the CT1600 to drive it.
How's that little upgrade coming along over there Bjt? 😊
Reply 6 of 24, by Mau1wurf1977
Yea I love that card. As a speech / digital card next to MIDI it's perfect 😀
Sound Blaster Pro 2 is also nice. But the swapped L and R annoys me. Yamaha chip cards are also good. I have this Audician card, but the driver annoys me. Can't disable the WSS and so it takes up lots of resources. But maybe there are better drivers?
ESS Audio drives are also nice. But after all is said and done I usually go back to my AWE64 GOLD 😁
My YouTube channel
Reply 7 of 24, by bristlehog
I have a Roland MCB-1 and can thus hook anything to my LAPC-I, be it external MIDI devices, or, vice-versa, something that sends in MIDI data so that the LAPC-I PC becomes sort-of CM-32L.
What's the point in using CT1600 instead of CT2760? I don't intend playing games much on that PC, so an issue of some older games being compatible with SB Pro but glitchy with SB16 doesn't bother me.
To turn this PC in a convinient-to-use DOS XMIDI jukebox I am currently developing a XMIDI player. After I fix few remaining bugs, I will probably release it to the public. However, I am quite unsure if XMIDI bothers anyone except myself.
Reply 8 of 24, by Mau1wurf1977
Whenever you have two cards, one that does MIDI, another that does speech / digital, you will have no issues with hanging notes and so on. Many do this to avoid hanging notes on Creative cards.
My YouTube channel
Reply 9 of 24, by Kahenraz
Roland LAPC-I + SB16 CT1730 (rev 4.03) should be all you need. Then just hook up a Yamaha and SC-55 for the tunes which sound best on them.
That's kind of what I'm doing but I've got a Roland SCC-1 + SB16 with a MT32, CM32L, and Yamaha synth.
Reply 10 of 24, by 5u3
CT2760
LAPC-I
GUS MAX
XMIDI player as in MSS/AIL files?
Reply 11 of 24, by carlostex
Ummm... I disagree that it takes a lot of resources. In fact it takes up so little resources. You didn't play with the card long enough.
I do agree SETUPSA is annoying. But whatever you select for Sound Blaster you can select for WSS. WSS is not going to work properly, but you won't need it either. FM output is good as digital is too. These chipsets can do Sound Blaster Pro Stereo and mix @44KHz. In fact, when running a tracker program i found it to be very close quality wise to my Gravis Ultrasounds. It has only slightly less lower SNR compared to the GUS.
The advantages of the OPL3-SAx cards eclipse the disadvantages. And some disadvantages are just nitpicking really.
Currently on my SS7 system i have:
- SBPro 2 CT1600;
- Yamaha YMF719 (just for MPU-401 using IRQ9);
- GUS MAX;
I gave this setup a try, but to be honest the compatibility advantage of the SBPro 2 over the Yamaha card is something that in my case is just non-existant. I might actually ditch the CT1600 in the end.
My vote goes for Yamaha chipset and GUS MAX.
If you won't use external synths i would go with CT1600 and LAPC-I.
Reply 12 of 24, by badmojo
Really? I'm no audiophile but the the SB Pro 2 just sounds so much nicer to my humble ears. SNR, etc aside, for actual gaming purposes with SB Pro era games (~92), the SB Pro just sounds nicer. Those Yamaha cards (I've tried 3) are all kinda crisp, thin, and lifeless in my experience.
Plus, Creative just ruuull11zzz
Reply 13 of 24, by bristlehog
Right, actually it is based on AIL 2 player.
Reply 14 of 24, by bjt
I bought an SB Pro 2 recently so can do some proper testing, now all I need is some time to do it 😀 Maybe over the holidays. In any case it won't be a magic bullet cause it will only work with real-mode games (no DOS extenders).
Reply 15 of 24, by silentwulf
The SB16 will be your safest best. Probably the de facto in any retro PC.
If you want something interesting, go for the GUS. With some sound patches, it's a stunning card.
AWE64 is great, but I currently use mine for a Windows 98 machine 🤣
Has solid SB16 emulation too.
Oh, and yeah. MT-32 or SC-55 is a great addition too 😜
Reply 16 of 24, by Malik
I'm having
LAPC-I with MCB-1 to SC-55 MKII, and,
AWE32 CT-2760
in my 486 DX2-66 system.
Reply 17 of 24, by PeterLI
In a 486 / Pentium systems I usually install GM devices. I also like SB16s in 486 / Pentium systems. 😊
I keep the LAPC-I(s) for 8086/286/386. With SBPRO or SB1.5/2. 😊
The FB-01 is kind of fun with old Sierra games. But I sold mine 2 weeks ago. I may buy one (without box, cheap) again at some point. I just dislike modules. I am always short on desk space and all the cables annoy me. 🤣
Reply 18 of 24, by bristlehog
YOU! Thelyron Hashnitor!!
I nearly had a heart attack when my IBM Music Feature auto-search returned non-zero results. However, that was you offering a FB-01 bundle for sale and using 'IBM Music Feature card' string in lot description!
Reply 19 of 24, by carlostex
Yes.
Of course, it depends on actual taste. I actually love the Sound Blaster Pro, it's one of my favorite Creative cards. Tell you something, i don't like the fact that the Yamaha cards are budget. In my opinion the YMF chipsets are excellent, and sometimes i wonder abiut this chipset built into a better design card with better filtering and components. I think it's a chipset that would deserved higher quality board design.
As far as sound goes yes there are differences, but having tried loads of OPL3 cards, Creative and others , the cards with the YMF chipset are the ones that sound best to me. Compared to the CT1600, it sounds a little thinner because it probably cuts a bit on low frequencies, but with my mixer i can make it sound very very close to the Pro 2. Granted the software is not user friendly and a bit weird with virtually no documentation, but it's a problem out of my way because i've dealt with it enough. Oh and BTW, the card sounds great when mixing stereo at 44KHz, something a real Pro 2 cannot do. I dare to say it then sounds pretty close to a GUS quality wise. This is a card that just works for me, and gives me absolutely 0 problems.
Creatived tottaly ruled the market, but often competitors had technically better products.
