First post, by Megadisk
Ok, my setup is a IBM/Sega Teradrive PC (AT 286 10Mhz) 2.5MB Max ram, and a 20MB HD. Running the Japanese IBM DOS J4.0V Rev 4.06 translated into Engrish.
I installed a SB PRO2 CT1600 sound card with the drivers and updates, but I'm having a problem with the DOS game Golden Axe. For some reason the sound effects aren't there most of the time, the music part is just fine. The funny thing is that if I load another game first such as Outrun, then the sound effects some how mysteriously show up.
My AUTOEXEC.BAT shows:
SET BLASTER=A220 I5 D1 T4
@echo off
set sys=C:
set comspec=C:\dos\command.com
SET SOUND=C:\SBPRO
SET MIDI=SYNTH:1 MAP:E
C:\SBPRO\SBP-SET /M:12 /VOC:12 /line:12 /CD:12 /FM:12
prompt $p$g
path C:\dos;
ver
and CONFIG.SYS :
DEVICE=C:\SBPRO\DRV\CTSBPRO.SYS /UNIT=0 /BLASTER=A:220 I:5 D:1
DEVICE=C:\SBPRO\DRV\CTMMSYS.SYS
FILES=40
buffers=20
REM ** files=20
shell=C:\dos\command.com /p /e:512
device=C:\dos\ansi.sys /x
The card jumpers match these settings. What could be causing the problem?. I had a SB16 in there before, and I was experiencing the same exact issue with it.
Thanks in advance for your input.
