^ Wow, a true ancient relic, that Seasonic SSA-200G AT must be ~20 years old.
· Harl! Notice the difference between lytic caps from a top-notch jap brand like Panasonic or Rubycon and pure crap like the Fuckyous: After two decades the Pannys and Rubys still look good 😈 , while the Fuckyous went belly up in no time 😁 . There also some CHTR (
) caps that look good also.
· It's well built, decent input filtering for its time (2 X-caps, 2 Y-caps, 1 common choke) and what could be a MOV. Monobloc rectifier bridge (as opposed to the four diode treatment typical of gutless wonders). Decently sized (for the low total power) 470uF Panny big caps.
· Overkill '35' size main trasformer. Double sided heatsink for the primary switchers. KA7500B controller. What looks like a AN7900 regulator on standalone heatsink.
· On the output filtering I see PI coils and decently sized Rubys.
· Notice also the connector for the mains wires, instead of them just soldered to the PCB. This makes tinkering much easier 😀 .
Hidden treasure no doubt, if you're not interested I'll provide her a new home 😁 .
keropi wrote:TELVM, is the above comment targeted for the 350W psu I posted before?
Yep in my previous post I was talking about the Levicom.
