First post, by ReeseRiverson
- Member
I've decided to nab my motherboard, which the numbers are 'P6FX1-A Rev 1.2', with an Intel Pentium Pro at 200MHz. With 32MB of RAM installed. I have my ATI Rage LT Pro PCI card installed. It had been well over 5 years since I last ran this board, which was out of a system that ran Windows 95. Had 16MB of a Compaq labeled RAM. POSTS fine and dandy, and boots from the floppy no problem. Load up the setup from Windows 95 disc I have, and after the setup on the CD does its thing... I enter the world of pain. 😦
Windows tries to load up for the first time, but I end up getting a "Fatal Exception 0E has occured at 2028:C00276E6". 😒
I've tried a few different harddrives and IDE cables. Just to rule them out... unless I have a case of bad luck with a bunch of bad drives, but I am not sure what to think at this point.
I would like to run Windows 95 on this machine since I already have a couple of machines running Windows 98SE. Then a few running DOS 6.22 and Windows 3.1. I suppose I may try Windows 98 for grins and giggles to see if it has difficulty but I can't seem to figure this one out. Any ideas?
