VOGONS Benchmark archive?
Reply 20 of 113, by elianda
It is nice to see that somebody from a country that has a fair use law is able to put such archive online.
For the benchmarks it would be necessary to give default settings for later comparison. Those should be chosen accordingly, that it runs also on a lower end system.
f.e. for FractInt, are you sure that this 2K resolution rendering would work on let's say a 2 MB 386.
For such cases maybe even a low end setting and a high end setting should be given.
Youtube Channel
Reply 21 of 113, by Mau1wurf1977
What's a good HDD benchmark for Windows 95/98? The question of storage pops up all the time...
Also if there is a service pack / patch pack that you Windows guys always use, we could include that as well. To have a common base so to speak.
My YouTube channel
Reply 22 of 113, by NitroX infinity
Include a text file with web-addresses to where they can download drivers. Wouldn't take up much space and very helpfull.
And one big zip file? You'd end up with a file that could be several gigabytes large. Especially if you include game-demos.
NitroX infinity's 3D Accelerators Arena | Yamaha RPA YGV611 & RPA2 YGV612 Info
Reply 23 of 113, by Skyscraper
PCmark 2002 is what I use to check HDD performance in Windows 98.
There are probably better choices.
I use Windows 98SE without updates.
The only thing I add is USB storage support.
I also install Direct X 8.1 if it is a fast Windows 98 system.
Reply 24 of 113, by vetz
You think of driver collections like found on falconfly.de for 3DFX drivers?
Gona's collection of ATI Rage drivers: http://gona.mactar.hu/ATI_3D_CIF/
My PowerVR collection: http://www.vogonsdrivers.com/getfile.php?fileid=488
I have started a collection for the Rendition Verite as well, but it's not complete at this point.
While no collection of every driver version, http://www.vintage3d.org/driver.php have drivers for all the early 3D cards.
Reply 25 of 113, by NitroX infinity
Basicly, anywhere where you can find a lot of drivers. Official manufacturer websites too like;
http://www.s3graphics.com/en/drivers/legacy_s … re_archive.aspx
http://www.matrox.com/graphics/en/support/drivers/latest/
Reply 26 of 113, by Mau1wurf1977
Ok I have started testing stuff.
Disk Speed 32: http://software.vgrin.host56.com/diskspeed32/
Works fine under W98SE.
Could you point me to downloads please? Having USB storage would make it a lot easier 😀
My YouTube channel
Reply 27 of 113, by jwt27
2048x1536 requires 3MB so that wouldn't work on such a system. OTOH it's not hard to make a 640x480 fractal that takes 5 minutes to render on a P2. I think you'd want to make it take at least a minute or so on fast systems, to limit quantization errors / variance (or whatever it's called). But then the same preset could take like an hour to render on 386. Making two or three presets for a different range of systems might be a good idea then... But that means you can't directly compare them anymore.
And I just thought, since fractint is available for multiple operating systems, this could also be used to measure performance difference between OS's on the same system.
Reply 28 of 113, by Mau1wurf1977
How about we share the pain and everyone tests and adds one benchmark at a time?
Basically test it under W98, if it works grab a screenshot, write a little bit about it and attach a ZIP.
I'll start with Drive Speed 32: Measures disk reading speed and plots a graph.
    DiskSpeed32.zip
    641.38 KiB
    151 downloads
My YouTube channel
Reply 29 of 113, by Mau1wurf1977
Roadkil's Disk Speed
Tests disk performance under various conditions.
    DskSpeed.zip
    46.82 KiB
    133 downloads
My YouTube channel
Reply 30 of 113, by Skyscraper
http://www.technical-assistance.co.uk/kb/usbmsd98.php
Reply 31 of 113, by NitroX infinity
May I suggest you use ultra compression with 7z instead of zip. Will save a lot of space. Unless 7z isn't available for DOS, in which case rar might be the better choice.
Reply 32 of 113, by Mau1wurf1977
Geeez don't you live in the land of super broadband 🤣
I live in the bush and it's not an issue 😀
7z is another tool someone needs to install and garble up their machine.
My YouTube channel
Reply 33 of 113, by NitroX infinity
7z might be another tool, but so is zip (or rar).
Reply 34 of 113, by Mau1wurf1977
vetz wrote:
Ok that one complains that a new version of Windows is needed.
My YouTube channel
Reply 35 of 113, by Mau1wurf1977
Windows 98 benching is fun! I had no idea 😊
Tested and added the following to the archive.
I will upload version 1.0 soon!
7-Zip
DX 8.1
3DMark 99 MAX
3DMark 2000
3DMark 2001 SE
PCMark 2002
SISoft Sandra 99
My YouTube channel
Reply 36 of 113, by Mau1wurf1977
And that's it for tonight!
I will update the first post with download links.
If someone wants to help out and type up a readme / file list, that would be awesome 😀
I've used 7 Zip at Ultra and created a self-extracting archive. Happy? 🤣
Added the following:
WinTune 98
3D WinBench 2000
Crystal CPU ID
Everest
Crystal Mark 2004 OpelGL Part
My YouTube channel
Reply 37 of 113, by 5u3
Did you know there was a Direct3D version of PCPbench? It's very old (1997) and probably not very useful, but since it seems to have vanished from the net, here it is:
    PCPBenchD3D_2.10.zip
    567.09 KiB
    245 downloads
    PC Player D3D Benchmark v2.10
Reply 38 of 113, by Mau1wurf1977
Nice! Definitely will get added.
Version 1.0 of the archive is uploading (200 MB) and I'm going to bed 😵
I'll add it with the, hopefully heaps of other benchmarks, tomorrow 🤣
My YouTube channel
Reply 39 of 113, by leileilol
vetz wrote:
MDK2 also got one
The demo has the benchmark too and the filesize can be greatly be dropped to around 35mb leaving in just the one song used for that particular level. The demo also has a patch 😀
