First post, by dehavilland
Environment: Archlinux. DOSBOX SVN 3858 with NE2000 patch
The emulated ethernet card seems to be set up properly. I added my current user to the pcap group to avoid running dosbox as root.
DOSBox version SVNCopyright 2002-2013 DOSBox Team, published under GNU GPL.---CONFIG:Loading primary settings from config file /home/highcheng/.dosbox/dosbox-SVN.confMIXER:Got different values from SDL: freq 44100, blocksize 512ALSA:Client initialised [128:0]MIDI:Opened device:alsaUsing Network interface:wlan0(no description)
And my packet driver software interrupt is 0x60, interrupt number 0x3, Ethernet address is AC:DE:48:88:99:AA.
Everything seems to be fine until I run the DHCP.EXE of mtcp. All DHCP request got timeouts and it said
Your DHCP server never responded, but your Ethernet card is receiving packets.
And I tried to set up the gateway, netmask and DHCP address manually. It didn't work, either.
Update 20140128
I found the problem. When I use the cable instead of wifi, it works without using an disk image!
wrote:Using Network interface:
wlan0Does that mean you're actually using a wifi card? Most wifi cards are unable to spoof MAC addresses so they don't work in setups like this...
Thank you!
Amibay username:winstonwu91
Recent wants:A cheap intelligent midi interface card, a good record player
A young Chinese student studying in US, drives a vintage car, use a vintage typewriter and loves vintage PC.
