First post, by Fexel
Im using a SVN Daum Build Win95c Dosbox. Works so far.
Now i want to integrate an 8gig hd to my emulated os (as second hd).
In my Autoexe is the following:
imgmount 2 .\images\c.img -size 512,63,16,711 -t hdd -fs none -ide 1m
imgmount d .\images\d.img -size 512,63,255,1023 -t hdd -fs none -ide 2m
boot -l c
IDE Categorie is like this:
[ide, primary]
# enable: Enable IDE interface
# int13fakeio: If set, force IDE state change on certain INT 13h commands.
# IDE registers will be changed as if BIOS had carried out the action.
# If you are running Windows 3.11 or Windows 3.11 Windows for Workgroups
# you must enable this option (and use -reservecyl 1) if you want 32-bit
# disk access to work correctly in DOSBox.
# int13fakev86io: If set, and int13fakeio is set, certain INT 13h commands will
# cause IDE emulation to issue fake CPU I/O traps (GPF) in
# virtual 8086 mode and a fake IRQ signal. you must enable this option
# if you want 32-bit disk access in Windows 95 to work with DOSBox.
enable=true
int13fakeio=false
int13fakev86io=true
[ide, secondary]
enable=true
int13fakeio=false
int13fakev86io=true
[ide, tertiary]
enable=false
int13fakeio=false
int13fakev86io=false
[ide, quaternary]
enable=false
int13fakeio=false
I cant integrate it to the os.. Any Idea?
