First post, by NetPCDoc
I am new to DOSBox - and I have a couple of problems ...
For supported games - is there a way to get recommended configuration settings? (values to "plug into" / "change in" dosbox.conf?)
(The answers I am looking for might be amoungst these recommended settings...)
Then with the DOS install of Sim City 2000 Special Edition (I actually had the original cd gathering dust on a shelf!)
Using DOSBox-0.74 - with default .conf - on an HP Laptop running Windows Vista Ultimate 64-bit OS
The game plays great ... until I try to exit out (or run the WILLTV videos) ... when exiting SC2K the systems hangs on a blank screen with a cursor flashing on/about line 2
seems that the .exe is not properly returning control back to the .bat - is this a known issue with a known fix?
I have SC2K's SCURK.com working fine - and it exits properly! - the readme would lead one to believe SCURK would be giving most problems.
Having made an .iso of the cdrom - WILLTV will run properly, if run independantly of the main game's .bat file (which runs SC2K's exe before giving option to do WILLTV).
And in Sim City (the classic DOS 3.3 or better build) - the mouse (or touchpad?) appears to be a bit irratic, jumping around and just about anything except moving smoothly in any given direction; I suspect that the proper .conf values will fix this - if I could just find said proper values!
