Robin4 wrote:Want to finish my fastest win98se build (maybe iam going to make a dual boot xp with it, but iam not sure for now)
So i decided  […]
So i decided to find a good solution for that build.
The case is absolutely perfect, but the inner component where not.. I was not happy about the motherboard (maybe i sell it later, iam not sure about that)
But trying find a good Socket A (462) board isnt funny nowdays.. Its much easier to find much older motherboards like 286 - till socket 7) Because most people stored them away..
And when people going to recycle for gold they trashed mostly the newer stuff, like slot1 / socket 370 / socket 462 motherboards.. I really couldnt find anything in my country.. So i had to look further.
I decided to look for better socket A motherboards. But the newer doesnt have that one ISA slot anymore.. So i thought about that.. I decided that i need to drop the ISA slot idea.. But most cards in that days where usual pci expension cards. Then one other problem i had to cope with.. The limited ISA slots. 6 PCI slots on early S462 where normal in these days, but now on the newer boards i had only 5.
So my plan was to look for a board with intergraded NIC onboard so i could spare one PCI slot..
Then looking for a board (didnt want to spend that much actually)
I found this board:
MSI K7N2 Delta2 Ver 1.0 I dont know if its any good..
What iam beware of, it cant boot SATA disks in windows 98SE/ME (only from windows xp i guess) So actually i need use PATA instead for the older OSses, maybe there is a walk through fix for it)
I also saw that the newer version does have a chipset cooling (fan) on it, so i guess this one could be very hot (iam not going to oc the system) Then i can always replace the heatsink with a fan.
I just have to test that motherboard and sees if it would work out.
On the second board, it was close your eyes and press the buy button..
There where already some watchers on this one.. Maybe it was a little bit expensive.. But i just love New In Box things..
So i dont get headache to find that I/o Shield, then ill ready have a board i can use from the box with everthing included:
http://www.ebay.com/itm/281150243184?ssPageNa … 984.m1497.l2648
Yesterday i already bought two socket A motherboards. One i got very cheap, the other is more expensive, but that board comes new in box with everthing included.. ( first time i didnt wanted to spend to much money on it) But i dont like to hassle it comes with (no manual, no cables, no I/O shield ect) I had thought about the fact if it would be a great idea to go for an older board.. The newer boards having 5 pci slots instead of 6 on the older ones, this could tackle my upgrade options on the system, because the sytem would have 2 voodoo2 in SLI onboard, and wanted to install an PCI soundcard, NIC card maybe other I/O cards.
So i thought that it wouldnt be better to find a board with intergraded NIC on the board it self, so i could spare one PCI slot.. And having more room for upgrade PCI boards..
I had already looked at that Asus A7V333 board, for me its a no-go if i wanted to still use SLI and also needed to install a nic to the board *to limited pci slots) And the board i had bought yesterday do have more processor options, and the quality of these boards are much better.. LGA775 iam not intrested on for this system. I have already a S775 system that i will run the latest windows XP on, but iam guessing to dualboot that system with windows 7 32-bit.
Now lets go further on this system..
I have a nice quality case
Now i have 2 nice MSI motherboards:
MSI K7N2 Delta2-FSR
MSI K7N2 Delta2-LSR (this NIC doesnt support Gigabit)
Want to use an Athlon xp 2600+ 266Mhz in it (processors i had already)
I think to go with at least 1GB of memory. ( i think i have still 1GB DDR400 here)
Harddisk iam think of going with 250GB (and split the disk with 2 partitions 125GB each)
Now i have a Nvidia Gforce 4 here from Asus.. ( is it wise to upgrade it to 6800 series maybe 7800 series)
Dont know which operating system to install.. I like to install windows 98 se on it, but give me some limitations i think..
1. I need to edit the config file to support 1GB in windows 98se ( so i think would it be better to go with windows ME / Win2000. ( i know Windows ME having those bug, lets go later further on this)
2. I think i go to run in problems, because windows 98 se dont using LBA-48 to support bigger disks then 137GB.. ( maybe an 250GB disk would be enough splitting it in two partitions.) But i would limited me here on bigger disks.
First why windows ME?
I know of the bugs in this OS, i only have seen that there are unofficial SPs and fixes for this OS.. I like to know, do these unofficial patches fixes those bad bugs in that operating system? Or would it still be worse to use it?
My other bet is Windows 2000.. I know this operating system was designed for office / work instead of home entertaining / home use.. I know back in the time there where games that also supported that OS.. I dont know how much of those games where supported because i had never used windows2000 before (in that time i already using windows xp instead)
Is windows 2000 a good platform to play windows 98 supported on (games that wont run on windows xp, with fiddling on compatibiliy modus)
With this system, iam trying to aim more on games that wont run on my slow pentium III 550Mhz system and till the first period of windows2000 /windows xp. All of the faster games for windows xp i can play it on my S775 rig.
