First post, by MrFlibble
- Oldbie
I'm sorry if this has been asked (and dealt with before), but I searched the forums and haven't found anything that would address this particular issue.
Basically, when I run a game that has a 320x200 VGA mode with the default DOSBox settings and take screenshots, they retain the original dimensions (320x200). However if I switch to the vgaonly mode the screenshots are scaled up to 640x400. The scaler is set to normal2x in both cases. Is that the correct behaviour? If not, why does this happen?
