First post, by lavigj
Has anyone had any luck getting past a "Privateer CD not found." error on winXP?
I am pretty sure that the CD is mounting correctly because I can browse the CD in DOSbox.
Any help would be appreciated.
Reply 1 of 9, by lavigj
sorry, forgot to include vital stats:
Athlon XP 2400+
MSI KT600 mobo
1024 DDR333
GeForce FX5200 w/Detonator 53.03 driver
Samsung CDRW SW-232B
Pioneer DVD-106S
Reply 2 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
Well that is a bad assumption. You can mount cd in at least 4 different ways and with each one the cd is readable from within dosbox.
Try looking at the mount command in the readme
Water flows down the stream
Reply 3 of 9, by lavigj
Well, I tried about sixteen different mount methods on both drives, all resulting in "Privateer CD not found., <br> JEMM unloading.
mount d f:\ -t cdrom
fail
mount d f:\ -ioctl
fail
mount d f:\ -aspi
fail
mount d f:\ -usecd 1
fail
mount d f:\ -t cdrom -aspi
MSCDEX: Failure: Path not valid. Drive D mounted as CDRom.
mount d f:\ -t cdrom -ioctl
MSCDEX Installed.
mount d f:\ -t cdrom -usecd 1
MSCDEX installed.
mount d f:\ -t cdrom -usecd 1 -ioctl
MSCDEX installed.
mount d e:\ -t cdrom
MSCDEX installed.
mount d e:\ -ioctl
Drive D mounted as local diretory e:\
mount d e:\ -aspi
mount d e:\ -usecd 0
MSCDEX installed
mount d e:\ -t cdrom -aspi
mount d e:\ -t cdrom -ioctl
MSCDEX installed.
mount d e:\ -t cdrom -usecd 0 -ioctl
MSCDEX installed.
So, not much luck overall after starting and restarting DOSBox sixteen times, but it appears that I might have better luck with the samsung drive. ( e: )
I do remember that Privateer required a certain version of MSCDEX to work, but I don't recall off hand what it was.
Any further input would be appreciated.
Reply 4 of 9, by GreyDog
Hello all...n00b here!
I'm having the same problem:
MSCDEX installed.
but I still get the jemm error.
I would like to try the -lable function but have no idea what the lable is or how to find it!
could one of you fine folks point me in the right direction?
many thanks!
fine prog you got here, I'm excited to see it working!
specs:
P4, 2.6 gig
512mb ram
ATAPI 48x cdrom
Reply 5 of 9, by Magamo
The easiest way to get around this problem, I should think, would be to copy priv.tre and rf.tre to the same directory as the rest of the game install (If we are talking about the Deluxe all-talkie CD version) and then edit your priv.cfg and rf.cfg files to point to C:priv.tre and C:rf.tre respectively.
Note that it will probably take about 200MB of space to do this, but I've not had any issues at all.
On top of that, Qbix, Harekjet, Snover, et. al, with the latest CVS version Privateer runs much better on my PIII/600 than it did with 0.61. I'm guessing there's been some massive optimizations with the CPU paging support happening lately.
Reply 6 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
hmm maybe in the way it's compiled.
Or do you compile it yourself ?
Reply 7 of 9, by voyageur
I have binaries of both 0.61 and CVS compiled with the same flags. Privateer runs a lot lot lot faster on the CVS version (and is playable on my box!) compared to 0.61.
So the speedup is not related to the way dosbox is compiled (or some changes allowed gcc to do some more optimisations 😉 )
Voyageur
Reply 8 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
well the cvs is quite different then 0.61.
So it's possible.
I think mouse control within privateer should be better as well.
Reply 9 of 9, by GreyDog
Well I got it running!!
mount f f:\ -t cdrom -usecd 1
I assumed the first drive letter was what Dosbox called it. I didnt realize it actually used it.
doh!!
it was real choppy & crashed before the intro finished, but I suppose a little tweaking will fix that.
thanks, pointing out the games config files is what allowed me to discover my error 😉
"ye don't sweat the petty things"
