First post, by Cypher402
Hey Everyone,
Thanks for taking the time to read this. I've done a lot of searching about various issues I'm having getting the Voodoo 5 5550 to play older Glide titles and what not, I've managed to solve most of them but it has been hard. At this point I'm running out of stamina so I'm going to ask the community.
The idea behind this system was to be able to play older titles at 4XFSAA, but I'm wondering now if I should throw a Voodoo 2 or 1 in the system for betting compatibility. I'm curious what you guys think. My biggest concern is running the games at the absolute max settings I can achieve with 4XFSAA, which is why I've been avoiding using the older Voodoo cards for this project. I'm aware there is other versions of Quake, and I'm open to suggestions on using something else as long as it the exact same as the retro experience. I really just want to play GLquake like the old days (but with better res etc than what I could do on my voodoo 1 back then), which is why I'm avoiding the other remakes and what not. I'm using an original quake CD, the versions are (GL .95) 1.09
EDIT: The error I get when running GLQuake "wglCreateContect failed" I've googled this quite a bit and found nothing but dead ends. Sorry if the fix is obvious.
On a side note, and I didn't want to start a new thread for this. Is anyone else disappointed with the Voodoo 5s performance? I got Need for Speed High Stakes running on it, and doing 4xFSAA @ 1024x768 looks like a slide show. So I built a 2800+ Athlon XP with an old 3.3 volt AGP slot, and tried it on there. SAME THING!! Pretty much no performance gain, looks like a slide show. Though 2x is pretty smooth on there and not on the P3 450mhz machine. I was just surprised, but I suppose 4xFSAA is meant for lower resolutions? Is there something I can do to make it run better on higher CPUs? I really need to research the advanced options in the drivers.
This brings up another question, is this a waste of time? Would using a Glide wrapper on my modern system for NFS:HS allow me to run at higher res with better AA??
I want to believe that this retro rig is special and looks "better" than what I could do with a Glide wrapper, but is that true in your guys experience?
-Asus P2B-VE
-Pentium III 450Mhz
-128MB RAM (limited to 96MB in Windows)
-Voodoo 5 5500 (AmigaMerlin 2.9) Running at stock settings
-Sound Blaster Live! (Thanks to Vogons I found the driver disc. Surround sound and EAX work!!!)
-Windows 98SE
-DirectX 9.0C
If more info is needed, I apologize and will provide it as soon as I get home from work in several hours. Thanks for reading my rant.
Cypher
