First post, by Hazekel
Gretzky Hockey II crashes on DOSBOX. Does anyone know how to get it working? I cannot see any obvious answers.
Reply 1 of 9, by rgriff
Yeah, I've got the same problem. No matter what I try, DOSBox or VDMSound, the main game crashes back to the desktop after the intro. I do have WGH3 working tho.
Reply 2 of 9, by Hazekel
How did you get WGH3 to work. I can't get that one working either.
Reply 3 of 9, by rgriff
I have it working in DOSBox, but I had to change the DOSBox sound details to match the game's default for Soundblaster. It requires IRQ=10 and DMA=3. The games' batch file should have:
wgh3_k sblaster_pro irq:10 io:220 dma:3 manual_aim
Still, the game plays way too fast and the mouse movement is sluggish. I'll have to tweak with moslo or something.
Reply 4 of 9, by Hazekel
Thanks but some help here and two questions. As for your problem, I suggest using CNTL-F11 to slow it down. However, I am still having some problems. First, the game crashed whenever I try to load a different team, saying error #2. Second, I can't figure out the keyboard commands. Is there a way to adjust them, or a manuel online somehere?
Reply 5 of 9, by rgriff
I used the in-game speed bar to slow down the action. I was able to change teams ok. You have to make sure that your drive where the game is located is mounted in DOSBox. At first I didn't have it mounted because I was using the DOSBox command line. When I tried to change teams, it only showed the c drive and the z drive available. When I clicked the c drive..it had a teams folder with all the teams so I tried it. When I clicked 'done', I got that same error #2. After mounting the drive where my game is located, it showed up in the team selection page and changing teams worked fine. I only have the keyboard map from WGH2 which I've included. I don't think they match completely, though. I've only been able to use the mouse as a controller; the game hangs when I pick the joystick or keyboard.
Reply 6 of 9, by Hazekel
Thanks. Now if I could only get the stupid mouse to work better.
Reply 7 of 9, by rgriff
Yeah, it is a little sluggish. At least it's not a jerky mouse movement, tho.
Reply 8 of 9, by kerkko76
Does anyone have found the answer to the original question about WGH2 crashes?
I would really like to get this game work. It is the best hockey game ever. New NHL games might look good but they aren't real hockey, WGH2 is.
Reply 9 of 9, by Arc76
Hi, I couldn't even run WGH3. I got an error saying that "Sample Driver Not set to DEFAULT".
Does this have anything to do with the sblaster issue you mentioned? Please let me know. Thanks!!
