Minimal install for DOSBox/95 gaming
Files, FAQs, and other things to help you get your games running before you start asking questions.
Re: Minimal install for DOSBox/95 gaming
Postby Inuya5ha » 2014-1-01 @ 14:14
I want to try the manual guide from the first post, but what is the recommended Windows 95 version to use?
BTW, will DirectX6 work correctly in Age of Empires 2? I have installed Windows 98 with DirectX 8.0a, but there are certain graphic bugs. Only after installing DX9.0c the errors where fixed, but that version uses more than 60 MB.
Also, the guide in the first post was not updated since its creation date.. if improvements have been made, can someone please update the first post? Or at least implement the List tags for the steps, to make it more elegant? :happy:
User avatar
Inuya5ha
Postby leileilol » 2014-1-01 @ 16:39
No version of Windows 9X is recommended for DOSBox. You are purely doing so at your own risk.
by the way, DOSBox is not for running Windows 9x
User avatar
leileilol
Postby Inuya5ha » 2014-1-01 @ 21:03
leileilol wrote:No version of Windows 9X is recommended for DOSBox. You are purely doing so at your own risk.
I'm aware of that, let me rephrase my question in case it wasn't clear enough.
The topic creator mentions a "95 retail CD", what version is that Windows 95 retail CD exactly? And I do know I'm asking this at my own risk, the topic creator posted the topic at his own risk, and so on. :blah:
User avatar
Inuya5ha
Postby leileilol » 2014-1-01 @ 22:02
The retail version is the original August 1995 release with July 1995 file dates. It was never updated.
User avatar
leileilol
Postby Jarvik7 » 2014-1-02 @ 09:44
Truth is using win95B, I am using win95C.
Jarvik7
Postby Inaski007 » 2014-2-12 @ 06:55
Is there a list for what to remove from Win95c? I've seen *.diff files on this thread, how do you use those?
Inaski007
Postby Jarvik7 » 2014-2-12 @ 07:42
My post has the modified files themselves attached.
truth made the diffs from those.
Jarvik7
Postby Inaski007 » 2014-2-12 @ 08:50
Jarvik7 wrote:My post has the modified files themselves attached.
Thanks, found the files but can't find the exact place to put them. Inside one of the cab files?
Edit: I got it work, win folder only 27 MB. Thanks!
Inaski007
Postby Jarvik7 » 2014-2-12 @ 09:40
Inside the \WIN95\ folder is fine. Setup.exe looks there before checking the cabs.
Jarvik7
Postby beerbit » 2014-2-24 @ 17:08
There's a good standard install guide here:
http://dosbox95.dyndns.org
Would Virtual Clonedrive solve some problems like cdemu blacklists or securom type emulation? Also does Gravis Ultrasound offer better sound compatibility or is it about equal to sb16 9x?
Thanks
beerbit
Postby Jorpho » 2014-2-24 @ 19:41
beerbit wrote:Would Virtual Clonedrive solve some problems like cdemu blacklists or securom type emulation?
Daemon Tools, at least, is known for its ability to circumvent some kinds of copy protection. I don't know about Virtual Clonedrive.
I don't think anyone's ever mentioned trying to install Gravis drivers for Win9x in DOSBox. Maybe you should try it and find out. :cool:
User avatar
Jorpho
Postby beerbit » 2014-2-25 @ 00:25
Gravis Classic + MAX 95/98 drivers. Unfortunately they don't support DirectSound so it's all crummy software emulated lag. ;)
http://sta.c64.org/winprg.html
Reinstalled Win95 original and got VBEMP (2014) to work! svga_s3 card installed. Then removed s3 display driver + monitor from device manager. Then add hardware -> manually -> video -> have disk -> XGA version. Now I get all the hires goodness.
And for those getting dxdiag sound test garble - don't use pentium_mmx. Pentium works okay. Maybe someone will find the MMX problem and we can start playing those games too (Eraser: Turnabout). :D
beerbit
Postby Jarvik7 » 2014-2-27 @ 01:20
Thanks for the info re: sound garbling. Will try it out.
Jarvik7
Postby beerbit » 2014-3-01 @ 15:12
http://toastytech.com/files/comctl32.html
Comctl32.DLL version 5.00.0910.1306
From IE 5 beta
No resource leak under Windows 95 classic shell.
Programs like tsearch (1.4a - 1.6) need this to run (using plain Win95 1st ed). Not sure what else could benefit.
beerbit
Postby Jarvik7 » 2014-3-03 @ 01:23
Win95C has comctl32.dll version 4.70, so I would guess it's useful for more than just 1st edition.
I haven't run any updates against my install through I don't know if it's needed to this manual file switching.
Jarvik7
Postby Jarvik7 » 2014-3-05 @ 02:37
I just confirmed that switching to pentium cpu fixes sound corruption in dxdiag. However, dxdiag still crashes the machine when I exit it.
Jarvik7
Postby TheRealFreak » 2014-3-20 @ 11:02
Jarvik7 wrote:-Some of the audio tests in dxdiag are heavily distorted. All sound I've encountered in apps otherwise is fine. Maybe fixed with other SB16 drivers.
Using only DX5 solves these distortions (all 8 bit sound playback is affected and also games that use these, e.g. at least Fin Fin on Teo V1.5 and V3.5).
I've tried SB16 drivers (rev 14 and rev 16), but only DX5 solved this.
BTW, DX5 ships no dxdiag.exe, but the extracted files from DX6 works fine for DX5 too and does NOT crash when leaving dxdiag.exe used with DX5.
Jarvik7 wrote:-IDE controller has a (!) in device manager - using compatibility mode. Can fix with drivers?
When I DISABLE (=false) the ide ports the exclamation mark is gone in the device manager (driver still visible), but I',m still stuck to compatibility mode :-(
Jarvik7 wrote:-Haven't actually tried out any games yet, as I'm at work.
I've tried Fin Fin on Teo V1.5 and V3.5 and Creatures 1.04 (all patches applied) successfully yet (max cpu cycle limiting is required for me to avoid ab16 stuttering, e.g. 32768)
For other drivers I used the latest s3 trio 32 driver from s3graphics.com (legacy archive) and the latest 3dfx voodoo driver (from "the guru of 3d"), all on windows 95c.
One day was unfortunately not enough for me yet:-(
Good luck!
TheRealFreak
I'm working for my dreams come true...
TheRealFreak
Postby Jarvik7 » 2014-3-24 @ 02:00
Nice to know that games work.
I've been in to other things lately (teaching myself OpenGL starting from 1.0 - worked up to 2.1 so far), but the steps for my Win95c install have changed a bit. Removing the spooler is no longer recommended as a lot of things won't start without it (even if they don't use it) - even pbrush. I think just having the spooler .drv, but not the full install, is enough though.
@TheRealFreak: Try directx6 with the cpu set to regular pentium (non-mmx) in some games. dxdiag has correct sound in that configuration but still crashes on exit. Hopefully it doesn't crash in games...
DirectX 8 also needs some testing. truth recommended against it but provided no hard examples. If it doesn't lower performance or stability, having the newest gfx api supported is a benefit I think.
Jarvik7
Postby slimbag » 2014-6-07 @ 07:56
Not sure where to post or if someone could help:
I have Win98SE dosbox install with 3dfx voodoo emu enabled.
Games run fine in software mode (half-life, tomb raider 2, blood 2) but performance is terrible when I select the 3dfx voodoo. games run between 10-15fps, is this normal or is my setup broken ? Shouldn't I get better performance with the voodoo emulation over software mode ?
slimbag
Postby leileilol » 2014-6-07 @ 23:22
It's meant to be slow because it is a software rasterizer.
User avatar
leileilol
PreviousNext
Return to Deep Thought
Who is online
Users browsing this forum: No registered users and 0 guests
