First post, by Mau1wurf1977
Finally managed to finish this project. Here the video:
http://www.youtube.com/watch?v=tbNZBa2QO9c
My YouTube channel
Reply 1 of 17, by F2bnp
Nice! Do you remember the settings used for each game? How about testing with Pentium MMX and K6?
Reply 2 of 17, by Mau1wurf1977
I was so busy, this took me weeks 😒
I might do MMX, but want to move on a Voodoo 2 on a P3 platform.
Settings are all defaults.
My YouTube channel
Reply 3 of 17, by F2bnp
I could do some tests with Voodoo 1 or 2 (SLI as well). I own a Pentium 133, an MMX 233 and a K6-3+ which I can probably underclock or slightly overclock for this purpose.
I could also go with either an Alladdin V board or a 430TX board.
Reply 4 of 17, by sunaiac
Nice !
Since gains seem to be on Turok and Incoming, I guess My P133 can stay in my P5-133 without fear of getting replaced by a 200MHz as soon as I put a Voodoo inside !
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 6 of 17, by nforce4max
Nice vid and at least time you picked a better soundtrack, was tempted to send you some links 🤣
Reply 7 of 17, by F2bnp
Wow, this is eye opening to say the list. The P166 MMX is a good deal faster than the P200. The extra cache really helps the Voodoo it seems!
Reply 8 of 17, by swaaye
Yeah a Pentium will pretty heavily bottleneck Voodoo1. The scaling of those results make it obvious it has a lot of headroom.
Reply 10 of 17, by Mau1wurf1977
Tried a K6-2 and as soon every game just displays a green image. Sometimes it's blue. Basically a solid colour and the machine hangs.
Any ideas AMD fans, otherwise I will just leave testing AMD CPUs. Do I need an AMD CPU driver for Windows?
My YouTube channel
Reply 11 of 17, by Tetrium
A guess, but if you're using Windows 95, I thought it had a bug with CPU's above a certain speed? I don't know what else could cause this unless the CPU is defective somehow or it is a VIA bug of some kind.
My retro rigs (old topic)
Report spammers here!
Reply 12 of 17, by Mau1wurf1977
Tried a K6-2+ and K6-III+.
The speed bug affects only the older W95 versions and manifests itself in a totally different error.
If I put back an Intel CPU all is well.
It crashed when probing or initialising the card. For example in Turok demo just before you can press the button to start the game.
Didn't find anything on google either.
Wondering if a re-install could help?
My YouTube channel
Reply 13 of 17, by Nahkri
U didn't reinstall windows 95,after changing to a amd processor?
Couse if u didn't u should,after all the proc has a different architecture
Reply 14 of 17, by Mau1wurf1977
Weird I did have the reference drivers loaded. Installed the Monster drivers and it's working now. 😕
PS: And yes, I needed that AMD K6-2 patch for anything faster than K6-2/300.
Continuing the benchmark saga...
My YouTube channel
Reply 15 of 17, by Mau1wurf1977
Finally moving forward with my massive Voodoo 2 CPU scaling project. Done with Socket and Super Socket 7 processors. Done all the charts and tables and now I'm going straight to socket 370. Main reason is I don't have many of the slower Slot 1 CPUs, like a PII 233 or something like that. My neighbour does, so in the meantime S370 it is 😀
For those who don't know, I'm working on a "from 100 MHz to 3.2 GHz" Voodoo 2 (and SLI) CPU scaling project 😵
Started with the top dog to make sure everything works stably.
The board is pretty decent. I like AOpen. They always use Japanese capacitors so there are little stability issues. This one has an Intel chipset, Tualatin support and AGP. Perfect.
When mounting a CPU cooler onto a Tualatin, be very careful as the chips have a IHS. I snapped the mounting bit off a very decent board in the beginning of the year. So this time I just mount a small SS7 cooler with a Zalman 120mm fan blowing 😀
Storage is, once again, a modern SATA drive with 32GB capacity limit enabled (SEATOOLS) going through a SATA to IDE adapter. Works beautifully.
Wondering if I need chipset driver, but I will find out soon.
My YouTube channel
Reply 16 of 17, by GeorgeMan
Go for it! I'm thinking of keeping a Pentium 4 machine with i865 chipset, GeForce 6800 and a voodoo2 for dual booting windows 98se and xp and I wonder how would it scale!
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 17 of 17, by Mau1wurf1977
This is with just a single card:
https://www.youtube.com/watch?v=c4LfByYFv8Y
But yes, P4 is a valid option 😀
With SLI I recommend running a refresh rate of 85 Hz and enabling V-sync (on a CRT that is). Without V-sync you will see SLI artifacts.
In general I believe that the P4 platform will soon receive a lot more retro love. It's really a very solid platform. Cheap as chips. Super stable and easy to find parts 😀
My YouTube channel
