Reply 20 of 109, by badmojo
keropi wrote:
First post edited, rom version 010 corrects the Wing Commander crashes, so basically the card just works fine. If you know another problematic game please tell me to test it.
Well done, good to know it's not the hardware. So where do I get me an EPROM with the newer firmware in it to upgrade my card? Do I have to keep an eye out for a dead card too?
Reply 21 of 109, by keropi
^ What version is your card? if there is no sticker on the rom chip then you can use MQDIAG from the driver disk I posted to find it out...
Updating the firmware requires removal of the original chip and the use of a 27C512 or compatible one to burn and solder the new firmware (on a socket preferably). I don't think you can get the firmware anywhere, what's the deal with Music Quest nowdays? Do they exist?
Reply 22 of 109, by DonutKing
I can program a new chip for you if I get a copy of the ROM dump. Is the ROM chip on the card UV erasable? If so, I can reprogram the same chip - if its a mask ROM with no window you'll need a new chip. I doubt a card that age would have a EEPROM.
Reply 24 of 109, by Logistics
If I recall correctly a local place to me has the MQX-16 for $25 or so. Always eye-ball it, but I have nothing to put it in so I just ignore it.
Reply 25 of 109, by PeterLI
Reply 26 of 109, by soviet conscript
hey. got my wing commander working. when you guys say it crashed after the intro did it freeze or just boot you to DOS? I get this error
"error while allocating memory"
INTRO.DAT #0 (ERR 2 PS-1 LB319958 FL0) at LP4
Reply 28 of 109, by n1mr0d
Are there any schematics of this card?
I'm sitting on a idea for a while, let's call it HardMPU, inspired on the XT-IDE project and SoftMPU. It is an ISA card with a 100% compatible MPU-401 interface, Waveblaster header and optionally an YMF262 chip (OPL3). It has to be a maiden design (no copyrighted code), and compatible with fast computers. The PCB's can be made cheaply in China.
VooDoo Power Asus CUBX-E 440BX PIII 1.4GHz GF4 Ti 4600 Voodoo2 SLI 12MB SBLive!+Drive SB16 CT2230 + NEC XR385
Nostalgia pc Vtech Laser Slimline DX4-100 16MB Acumos AVGA1 AWE32 CT3980 Roland MPU 401 MT32 SC88
Reply 29 of 109, by keropi
^ I've been meaning to strip down the components from the dead card , I only removed the rom so far and won't continue with the rest until I find someone with a desoldering station, the card is too fragile for my taste 🤣
If I ever strip it down I will scan the pcb.
Reply 30 of 109, by soviet conscript
got wing commander to run and I can doubly confirm it runs with the v.010
Reply 31 of 109, by keropi
today I finally made soviet conscript's breakout cable from the cables he sent me:
and here is a shot next to the original cable , needless to say the cable works perfect... Yellow tube is the OUT jack , couldn't think something better to differentiate it from the IN jack since they are the same...
and I have fixed the schematic on the 1st page, I had some errors due to pin mirroring (solder/front side...)
Reply 32 of 109, by sliderider
Ummm...shouldn't that have come with a dongle with the midi ports? You shouldn't have had to made your own cable to use it.
Here's a pic of the 8-bit card. The dongle is black. The 16-bit card has a white dongle. Oddly, the 16-bit card only uses a few pins of the extended part of the slot so it's not much longer than the 8-bit card. It makes me wonder how important those extra pins actually are and what they are used for.
16-bit card
3706751932_e7821732b3.jpg?v=0
Reply 33 of 109, by keropi
^ it should have but dongles are not always included in 2nd hand ebay stuff... look at the 1st post, my boxed card comes with a cable breakout , not a molded dongle. It's the same actually, the dongle was newer and cheaper to manufacture I guess...
Reply 34 of 109, by Great Hierophant
You would have to reverse engineer the ROM program the microcontroller uses. However, if you are using a microcontroller, how much more effort would it require to implement sound blaster capability?
Reply 35 of 109, by PeterLI
Reply 36 of 109, by sliderider
PeterLI wrote:
I also have both the 8BIT and 16BIT versions. The dongles are interchangeable.
Have you ever tested to see if the 16-bit card will work in an 8-bit slot? The front part of the two versions look like they both use the same pins.
Reply 37 of 109, by DonutKing
It should work, the 3 pins on the 16-bit portion of the ISA connector are just the IRQ 10, 11 and 12 lines. As long as you stick to IRQ9 or below, that card should work fine in an 8 bit slot.
Reply 38 of 109, by sliderider
Does anyone know if the 16-bit card has compatibility issues with any games?
