Reply 1 of 13, by Mau1wurf1977
- l33t++
Reply 2 of 13, by badmojo
- l33t
It might be the wrong version for the card you're using. I thought it was awful too until I realised I was using a newer version than I should have been, it actually works very well.
Try the one I uploaded to vogon drivers - you need the right version of MVSOUND.SYS too.
Reply 3 of 13, by Stojke
- l33t
I am using it in my Vectra pc. The card FCC ID is : IXW-PAS16NS
It used to work flawlessly before in the same PC, but now after uninstall its giving me problems.
[E]
I tried the vogons drivers version (that worked before when i had W3.11) but same thing.
Run time error R6003 - Integer divide by 0
[E]
Tried PAS16 studio MVSOUND.SYS, but same thing.
SET/GET FM,MIC,etc works but every time i try to SET/GET VOLUME i get an error 6003. Than nothing works.
Reply 4 of 13, by bristlehog
- Oldbie
wrote:now after uninstall its giving me problems
Expand that? What was that 'uninstall'?
Hardware comparisons and game system requirements: https://technical.city
Reply 5 of 13, by Stojke
Reply 6 of 13, by Cloudschatze
- Oldbie
wrote:Run time error R6003 - Integer divide by 0
Based on my own experience with that error, you most likely have an IRQ conflict with the "PAS" section of the card. Try using a different IRQ.
The "panel.exe" mixer that is included with TrakBlaster Pro should be usable otherwise.
Reply 7 of 13, by Stojke
- l33t
I see. I will remove everything except VGA adapter and PAS16.
PAS16 is sitting at IRQ3 / DMA3 , while SBEMU is sitting at IRQ5, DMA1.
With what Sound Blaster standards is PAS16 compatible?
Is it a problem if my Video Adapter rests at IRQ15? I dont have IDE controller activated. I use SCSI, and i think it uses IRQ2.
Reply 8 of 13, by Cloudschatze
- Oldbie
wrote:I see. I will remove everything except VGA adapter and PAS16.
Try just a bare-bones PAS configuration, adjusting the IRQ as necessary (e.g., device=c:\...\mvsound.sys d:3 q:7 s:0 m:0 j:0 t:1).
The MVD201 chipset found on the PAS16 variants is compatible with the Sound Blaster 2.0.
Reply 9 of 13, by Stojke
Reply 10 of 13, by bristlehog
- Oldbie
Try either another computer or another IRQ/DMA settings?
Reply 11 of 13, by Stojke
- l33t
I think the power supply might be weak.
The computer some times starts and beeps 4 times, short pause, than 4 times again. It is using Phoenix BIOS and i didn't see anywhere what does 4 -4 -4 ... mean.
When i removed Matrox Ultima from the computer it didn't beep any more... I will try the card in another computer.
Reply 12 of 13, by Stojke
- l33t
Exactly the same thing happens on Sound Blaster CT1690.
OPL3 when terminated emits a loud noise and it sounds very silent when operating.
What could be the problem here? I unloaded everything and it only starts up with Cute Mouse driver.
[E]
Seems to have been DMA problem of some kind.
CT1690 works fine now. Still goes crazy in LLSID.
Reply 13 of 13, by Stojke
- l33t
Bac to PAS again...
For the computer errors, it was an PCI socket error with the video card, the contacts were dirty, solved that a long time ago.
Now, PAS16 still gives me the damn R6003 run time error.
As long as i dont try to set the volume the card works. Could this be a card defect?
