Yamaha uninstalling?.
First post, by Nic-93
It says i stil have the S-YXG50 installed but i dont..is it somekind of code i need to remove?.
Reply 1 of 3, by Stojke
If you installed it before you need to do a complete un-install of it.
Remove all registry values and things like that.
I think there was also an remover application.
Reply 2 of 3, by Nic-93
thats why it keeps registering its there, it asks me if i want to un-install it.
Reply 3 of 3, by Nic-93
but the other problem is, there is a string in the registery i cant remove..
