First post, by Pingaloka
- Member
Hi guys, I'm having some problems with the Turbo LED Switch of a new computer case that I've just got.
The problem is that the Turbo LED doesn't change the number values when I press the Turbo button.
I supposse the signal for the LED Turbo to change has to come from the Turbo Button itself?
Here are some pictures:
1st and 2nd picture shows the turbo LED 3 cable (red, black and black) connected to 2 cables coming from the MOLEX.
I see that the red and black cables provide the electricity current, I don't know that the 3rd black cable is for
and where to connect it.
3rd and 4th picture shows the back of the LED, the 4 pins are the ones that recieve the current and that are suppose to make change the value from the ON/OFF Turbo. There are 4 pins, but only 3 of them are used right now?!
5th picture is the back of the Turbo Button. 3 cables come out which are the TURBO SWITCH itself that goes to the motherboard.
So maybe I should try soldering a/some cable/s to the button itself to the TURBo LED Pin that is on the left? Just one Pin? Maybe two?
I'm completely lost!!
I'm a completely lost!
