First post, by Dakkiller
One of them died on my Am5x86 build (This isn't the one that died but it does use the same connections) and I wanted to know which connections it uses (I'm thinking about buying one of those Flash Card Solution drives that I keep hearing about all the time)
Reply 1 of 15, by keropi
that's an IDE drive , nothing more can be told from this picture
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 2 of 15, by Dakkiller
Thanks for letting me know.
Now I'll know what to look for
Reply 3 of 15, by LunarG
This made me feel really old... When people don't recognize IDE on sight anymore. *cry*
WinXP : PIII 1.4GHz, 512MB RAM, 73GB SCSI HDD, Matrox Parhelia, SB Audigy 2.
Win98se : K6-3+ 500MHz, 256MB RAM, 80GB HDD, Matrox Millennium G400 MAX, Voodoo 2, SW1000XG.
DOS6.22 : Intel DX4, 64MB RAM, 1.6GB HDD, Diamond Stealth64 DRAM, GUS 1MB, SB16.
Reply 4 of 15, by leileilol
IDE was only totally deprecated 3 years ago!
Reply 5 of 15, by obobskivich
Seriously. I clicked into this thinking we'd be ID'ing some IBM or Apple relic from the 1970s, or an older SCSI drive; not PATA. 🤣
Kids these days... 😜
Dakkiller: If you want to use flash memory what you're specifically looking for is a "CF to IDE" or "CF to PATA" adapter. Otherwise you'll be dealing with used hard-drives (most "refurbs" or "As new" that I've seen recently are anything but - they're pulls like everything else) that in some cases can have close to 100,000 runtime hours on them. Be careful when dealing with such used devices - they're mechanical and they do wear out after spinning at 4-10k RPM for YEARS continuously. With flash you have to worry about wear of the flash cell, and as far as I'm aware CF does not do wear-leveling like a modern SSD component.
If the computer is new enough, you may consider just adding a controller card to provide SATA and purchasing a brand new drive.
Reply 6 of 15, by RacoonRider
Me too 😀
Disk on chip is also an option, isn't it?
Reply 7 of 15, by obobskivich
You mean "DOM" or "Disk On Module"? My understanding is they're basically just CF cards as well, but built with the pin adapters on one package as opposed to relying on a stand-alone adapter (the advantage of an adapter is you can swap cards; some of them even take the place of an I/O shield to give you very neat drive swapping).
Anyways - yes they'd work just fine, but personally I'd go with an adapter + card solution, for economic reasons. DOM are usually marked-up because they target embedded applications - a quick look on Amazon shows 2-8GB models for $30-$40 and 32GB for $70. An adapter is $5-10 and a 64GB CF card is around $60. 😀
Reply 8 of 15, by RacoonRider
Yes, I always forget what they are called. I bought 1GB one for $6 from a local seller. Neat little thing.
Reply 9 of 15, by obobskivich
For $6 that's great, but I'm used to seeing them for more like $60. 😵
Also worth noting for the original guy: what kinds of limits on size does the computer or OS you're putting this drive into have? For example a 64GB card may not be a good choice if you're using DOS.
Reply 10 of 15, by sliderider
Wanna feel really old? I have two Corvus drives here,one with an 8 inch mech and the other with a 5.25" mech. They are 5 and 10 megabytes respectively.
Reply 11 of 15, by LunarG
My first PC was one of these: http://www.old-computers.com/MUSEUM/computer.asp?c=889&st=1.
It has two 5.25" floppy drives and no HD. I used it for playing Space Commanders, Zaxxon, Paratrooper and so on.
So yeah 😉 When people start having trouble recognizing a standard IDE HD, then I feel old 😁
Reply 12 of 15, by d1stortion
To quote Wikipedia:
Most CompactFlash flash-memory devices limit wear on blocks by varying the physical location to which a block is written. This process is called wear leveling. When using CompactFlash in ATA mode to take the place of the hard disk drive, wear leveling becomes critical because low-numbered blocks contain tables whose contents change frequently. Current CompactFlash cards spread the wear-leveling across the entire drive. The more advanced CompactFlash cards will move data that rarely changes to ensure all blocks wear evenly.
Reply 13 of 15, by obobskivich
Nice! Well in that case let the DOM flow!
Reply 14 of 15, by Tr3vor42532
That hard drive is definitely a Maxtor. That sticker along the top edge of the picture gives that away.
My YouTube channel: https://www.youtube.com/user/Tr3vor42532
Reply 15 of 15, by nforce4max
obobskivich wrote:
Seriously. I clicked into this thinking we'd be ID'ing some IBM or Apple relic from the 1970s, or an older SCSI drive; not PATA. […]
CF cards do wear-leveling but there is no garbage collection at all and even that might not be on all CF cards but many of them do have it.
