First post, by kato
I'm new to DOSbox, so I need some help here. I mounted the C directory I had my game in and got everything to work fine and dandy. I had my game, Master of Magic, and the DOSbox prompt said C:\MASTER, which was good, but then I typed MAGIC to play the game but it keeps saying I have to type INSTALL to configure it. I have configured it 986 times and everytime I can never start the game - please help me. Also, if there is another way to run the game easier with say, another program, lemme know, heh. Thank you.
Reply 1 of 2, by buddy53711
Are you using floppy or CD version? If you are using the CD version you need to mount your CDROM drive as well as the game directory. I got this going last night using mount d d:\ -t cdrom -label mpsmagic._cd
I am new to DOSBox as of last night so this is the only answer I have right now. The CD label may be different depending on what you have, but I would guess that there is a 99% chance it will be the same.
Reply 2 of 2, by buddy53711
Oh also, btw....sound didn't work so well once I got it going, but when i ran the install/configuration utility and switched from SBPro to the regular SoundBlaster, it worked fine.
