First post, by muralysunam
I would like to use a count variable and increment it as a part of command whenever dosbox is opened. I think the count should be stored in an external text file or something like that. I copy a particular file and rename it in serial order from name00.xls to name05.xls. After the name05.xls is copied. The copying must restart by overwriting name00.xls.
In short,
I have a file let name.xls
Whenever dosbox is opened name.xls is copied to namexx.xls where xx varies from 00 to 05.
Thank you for any help.
