Reply 20 of 24, by Auzner
wrote:It was more of a rhetorical question 😉
Yes, I was confusing you for being another "stuck in the past" type around here. I've seen some stupidly retrocentric threads around this place.
wrote:the readout of these displays were just set by myriad jumpers. I like them as much as the next man but I can understand why they fazed them out - they're just a gimmick and pain in the arse to set up.
There's a difference between just directly powering each segment or having logic to determine which set of segments will be lit. Obviously if the turbo button toggles both the frequency AND the display there is some form of input to it. I'm too young to know exactly what that was, but "jumpers" is using the same granularity as what I called "externalize."
