First post, by MLO
NOTE: I'm not entirely sure that this is a problem specific to Bioforge; it is the only game I'm currently working to configure.
OS: Windows 7 x64
CPU: Processor Intel(R) Core(TM) i5-2520M CPU @ 2.50GHz, 2501 Mhz, 2 Core(s), 4 Logical Processor(s)
RAM: 8GB
Sound: Intel integrated
Video: Intel HD Graphics 3000, DirectX
DOSBox: v0.74
I'm having some issues with configuring a Logitech Dual Action Controller with DOSBox; I'm attempting to disable the first analog joystick so that I can just use the second but regardless of what I configure...either in the .conf file or the keymapper...both analog joysticks are still enabled. The version of DOSBox I'm currently using came with Bioforge...which I purchased from GOG.
Any advice would be appreciated. Feel free to request more info.
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
Did you try setting the type to 2axis and then remap the joystick analog directions ?
Water flows down the stream
Reply 2 of 7, by MLO
I tried with 4axis_2, but not with 2axis. I'll try that and post back results.
Will configuring that setting disable the rest of the dual action controller buttons?
EDIT:
Interesting. After setting the type to 2axis and starting keymapper, the display (keymapper) shows two joysticks. I'll configure those, then try Bioforge again.
Another interesting note: I did not start up the dual action software before starting and configuring keymapper; maybe the software interferes with the keymapper in some way.
Reply 3 of 7, by MLO
Thanks Qbix...that did the trick.
NOTE: I had to go into the controller settings and swap the joysticks in order to make sure that the one I wanted to disable (the left) was disabled instead of the one I wanted to keep enabled (the right). Also, leaving the controller "profiler" off definitely seemed to help.
Reply 4 of 7, by MLO
Hmmm. I may have spoken too soon.
I set up a few mappings in keymapper, and launched Bioforge. Some of the mappings worked correctly, but others did not.
I exited Bioforge, went back into keymapper and found that the mappings I'd set up had completely changed. For example: I'd mapped button five to the Enter key, initially, but after I'd quit the game, the Enter key mapping was gone and button five was mapped to the Ctrl key.
Reply 6 of 7, by ElectricMonk
MLO wrote:
NOTE: I'm not entirely sure that this is a problem specific to Bioforge; it is the only game I'm currently working to configure […]
...snip...
The Logitech Dual Action is the issue. I used one for a few years, and had to find 3rd party workarounds for it all the time. Just bite the bullet, and get a wireless 360 Controller for your PC. I've had *ZERO* problems, since the swap out. Worst case, go to the rumblepad/Dual Action blogspot site. They try to get them to work with the latest games.
*EDIT*
If you want to use the newest controller from Xbox One, you'll need a new wireless dongle. The 360 one does NOT support it, per Microsoft.
*EDIT 2*
Anyone know of a good Flightcontroller Joystick, ala the venerable MS Sidewinder Pro? I have no desire to spend $400 on a HOTAS setup, that may or may not work with Tie Fighter, Xwing, Wing Commander, Strike Commander, etc...
Reply 7 of 7, by ElectricMonk
Didn't Bioforge support the keyboard only?
