First post, by stevemagin
Hi guys,
I've recently acquired a very odd P4 board: IEI ICPMB-8650GN-R12. The manufacturer is industrial partners, a firm I'm not to familiar with. Basically it's a P4 board with a northwood 3.0ghz processor, 2 isa slots and a agp 3.0 compliant socket. Interesting it also comes with a built in cf card socket as well as ide and sata ports.
I'm now looking to pair this with a suitable agp video card. I'd like to run win98se and play 1997-2001 era games.
I was also hoping to try out any decent glide wrappers to play old 3dfx games. I'm a little confused by what I've read so far but if I've understood correctly you need a dx9 capable card to use a glide wrapper, is this right? I suppose the other option is a pci voodoo card but they are pretty rare.
I don't have any specific preference for brand so long as it has solid win98se support, able to play dos games and supports a glide wrapper. At the moment my pick is a fx 5950 ultra, mainly because I've read that fx 6000 and above don't have good win98se support and I don't want to go xp.
Any guidance and advice greatly appreciated as always.
Thanks
Steve.
Reply 2 of 10, by AlphaWing
5700-5950 is a good choice nvidia drivers are solid as long as you stay away from the last few sets in 9x, which means staying away from the geforce6 series.
The Radeon 9700\9800pro is also good if you use the omega drivers, and aren't gonna be doing much in dos.
They can still be found here. http://www.omegadrivers.net/index.php?option= … 8-me&Itemid=133
The more power you have, the More AA and Anisotropic filtering you can apply 🤣 😈 . So 9700\9800pro and the 59xx's are probably the most ideal.
Reply 3 of 10, by nforce4max
The 5950 is a pretty good choice and is a good all rounder, the 9700/9800 series are really good cards but they do need after market coolers. VF700/900 series coolers are the best fit for the 9700/9800 series while the stock coolers for the 5900/5950 are pretty good when maintained.
Reply 4 of 10, by stevemagin
Thanks guys
Mau1wurf1977 good point re: 2001 games, I guess it would be later then perhaps up to 2004.
So 9800 pro or fx 5950 could do a glide wrapper like nglide or similar?
Interesting to know about the after market coolers on the ati cards. I'm guessing those coolers are hard to come buy these days?
Thanks all again.
S
Reply 5 of 10, by AlphaWing
The 9700 pro's stock sink isn't that bad, its pretty big covers everything.
The 9800 pro's on the other hand is a piece of junk, its actually got holes in it and you can see part of the gpu's heatspreader through it, without the fan its basically doing almost nothing.
5800,5900's I disable the fan take the metal cover off, and mount a PCI slot fan next to it or above it.
Reference fans on those are blower fans, which are very loud, especially on the 5800's, the reference heat-sink itself is quite good.
5700 ultra's are basically rebranded 5800's, they have a normal quiet fan, but still have the good sink of the 5800 and use ddr2 like the 5800, a very under-rated card.
Reply 6 of 10, by obobskivich
There are knock-offs of the VF700 easily found on ebay, or you could find an ATI Silencer (I forget which revision the 9800 requires); those seem to be relatively common.
You may want to consider other 5900 boards - 5950s tend to carry a hefty price premium compared to 5900XT/SE and 5900 Ultra on the used market, while the performance differences aren't all that dramatic. The same goes for the 9800XT vs other 9800 and 9700 boards. If you don't need extremely high resolution support the 5700 that alphawing mentions could be a perfect choice as well, along with the ATi equivalents from the 9500 (and I mean actual 9500, not 9550 - 9550 is slower) and 9600 series.
Reply 7 of 10, by stevemagin
Thanks heaps guys I think I'll try the 5900 just to see how it fairs and then I'll give the 9800 a whirl.
Much appreciated.
S
Reply 8 of 10, by obobskivich
They are no such thing. FX 5700 is NV36 and is derived from the NV35-refresh and released alongside the NV38 (FX 59590); they include the improvements to the shader units (including the third vertex shader that 5800 does not have). They are also missing 4 TMUs (and about 40M transistors) versus the NV30. The shader improvements will generally give them an advantage with SM2.0/DX9 content over NV30-derived parts (as with any comparison between NV30 and NV35), although against the 5800 Ultra they will likely be slower due to their lower clockspeed, lower TMU count, lower memory bandwidth, etc (I will also say the 5800U has been slightly faster than the 5900XT in my informal testing, and the 5900XT is generally faster than the 5700 series). They are available with either GDDR2 (early) and GDDR3 (later and ostensibly more common) variants, however the GDDR2 is clocked lower than on the 5800 series boards, as is the GPU. They use generally less power than the 5800 series, and require less substantial cooling (the reference 5700 boards are single-slot; the 5800 reference designs use dual-slot coolers - the 5800 Vanilla's cooler is very similar to what was later used on the 5900 Ultra). In general if you're going after a 5700 you want the GDDR3 variant, as they're faster. The 5900XT is a "better" choice though, imho, as it gives you the full 8 TMUs and 256-bit memory, and is more similar to the 5800 Ultra in terms of performance.
There is no "rebranded 5800" (e.g. NV30-based part) outside of the Quadro FX 1000 and 2000; the FX 1000 is a single-slot card, but is run at dramatically lower clocks than the "full" NV30 boards (FX 2000 and 5800 Vanilla both run at 400/800, and the 5800 Ultra at 500/1000 - the FX 1000 runs at clocks similar to the 5800 Ultra's idle/low-power state, which allows for it to be a physically smaller card (the 5800 Ultra can turn its fan off in idle/low-power)).
The base 5900 series does not use a blower fan of any sort - the 5900SE/XT/etc uses a relatively similar single-slot design to some of the GeForce 4 Ti and FX 5700 Ultra boards, and the 5900/5900 Ultra uses a cooler more similar to the 5800 Vanilla/FX 2000. Only the 5800 Ultra and 5950 Ultra actually included blowers in their reference designs (Flow FX and Flow FX II, respectively), although third-party makers like Abit and Gainward implemented blowers on some of their boards, and there are aftermarket coolers like the NV Silencer that use a blower design.
The simple single-slot sink design on the 5600/5700/5900XT is not suitable for fanless operation. The 5800 Ultra's cooler is only suitable for continuous fanless operation when the card is in low power mode; in performance mode the fan will (at minimum) cycle on and off, or (at maximum) run continuously until the card leaves performance mode (from my own observations it seems to depend on two factors: ambient temperature and complexity of the 3D load).
Reply 9 of 10, by RacoonRider
There are multiple overkill VGA coolers on ebay, mainly from China, that have universal mounting. I bought this one for 9800Pro:
http://www.ebay.com/itm/111222131985?_trksid= … K%3AMEBIDX%3AIT
Edit: It did require a little rework with a rasp (SMD components were on the way), but nothing hard. https://dl.dropboxusercontent.com/u/99196890/ … ns/P1030037.JPG
Reply 10 of 10, by Mau1wurf1977
I tried a few eBay coolers and found this one to be excellent:
Here mounted on a FX 5950 Ultra from Leadtek. I also got memory coolers because on this card they run very hot.
The FX 5950 Ultra has a temp sensor in the die and the cooler does a great job. It's also very quiet.
My YouTube channel
