What ISA-Card is this ?
First post, by dr.zeissler
Hi, can anybody tell me what Card that is and what connections are possible ?
All I know is that is a graphics card. i don't have anything other then the card.
Thx!
Doc
https://www.flickr.com/photos/94839221@N05/14 … 157633216840005
Reply 1 of 10, by Sammy
Because the "Data-Modul" on the Left side it seems to be a IO Card.
But the WD90C24A2 is a Graphics-Chip.
so is Don't Know... has it a VGA Connector?
Reply 2 of 10, by dr.zeissler
yes, VGA works fine, but what is the rest ?
Reply 3 of 10, by keropi
probably some old custom card, could be a part of a broadcasting setup , digitizer, genlock, you name it
Reply 4 of 10, by ElectricMonk
Don't suppose you could post a picture of the back of the PCB?
I'm coming up empty with data-modul BT 090, and I'm not easily finding a list of ISA cards that used WD90C24A2-ZZ chip. Maybe there will be an FCC number on the back?
Reply 7 of 10, by keropi
^ correct
btw, the company "DATA MODUL" ( http://www.data-modul.com/eu/home.html ) makes specialized display systems and embedded stuff, so your card is probably something they made 20 years ago. Just be happy it works as a standard vga, don't hope to make use of the rest of the unknown connectors on it without the rest of the kit the card was a part of... 😉
Reply 8 of 10, by ElectricMonk
I'm with keropi. I checked data-modul's site, and there's zero mention of that device on there. It's probably something that hit EOL eons ago.
Reply 9 of 10, by bestemor
looking at the top row of connectors, it may moonlight as a floppy + 2x IDE controller as well... ? 😀
The lower row must be for some control cable ?
Reply 10 of 10, by Sammy
IDE has 2x20 pins and i think this are 2x17 pins.
Maybe it helps to plug the Card in a Win95/98/2000 Machine and search for new Hardware.
Or an Linux System maybe it can detect the Rest of the Card.
