First post, by emodel
Hi
Id like to know if its possible to change aspect ratio.
To me, screen is too long (or wide), and not high enough.
I would prefer a more "square" window.
Is that possible ?
(if not, it would be nice to ad such a feature, imho)
thanks
Reply 1 of 11, by robertmo
search the forum...........
Reply 2 of 11, by emodel
Sorry i dont get it.
I dont wanna change resolution or something, i just wanna strectch Dosbox window so that its more "square".
In mame or fba (ie) most games are also 320*240, but the image is ok (and theres an option to change aspect ratio anyway).
What i would like is an option to make dosbox displays in a, say, 800*700 window, or 500*400 (epsxe has that, and its great).
Then, Open GL just stretches the original image so that it fill the window, whatever size it is.
Reply 3 of 11, by emodel
I got this :
i would like this :
Inst that possible ?
Reply 4 of 11, by Freddo
The first picture have the correct aspect ratio. 1,6 to 1 (320x200). It's the aspect ratio the vast majority of DOS games are using. Not the 1,3333 to 1 ratio (320x240) that is used today.
Reply 5 of 11, by Markus
You have to edit dosbox.conf.
In section [render] you can find "aspect=false", replace it with "aspect=true".
To change window size, look in section [sdl].
"output" must be set to one of overlay,opengl,openglnb, then try to change the value of "hwscale" until it fits your needs.
Reply 6 of 11, by emodel
You have to edit dosbox.conf. In section [render] you can find "aspect=false", replace it with "aspect=true". To change window s […]
These are my settings already.
Reply 7 of 11, by emodel
So you mean you had a 16/9 monitor (or so) on your 386 ?
Every monitor ive seen is rather square, so i dont see how you can say this is the proper aspect ratio. I dont talk of the original size (or what it shold be), i talk of what i used to see on pc monitors at the time (and still today).
Reply 8 of 11, by Markus
Computer monitors aren't "rather square", they almost have a screen proportion of 4:3.
VGA mode 13h (320x200) therefore uses pixelsizes that aren't square, they are vertically longer; when running in windowed mode, pixels are square, so the image has to be stretched to give a similar visual appearance.
"Aspect=true" perfectly works for me, so you should check again.
Or you might be using a "freaky" resolution or a "freaky" (notebook?)display - what are the proportions of the display and what resolution do you use?
Reply 9 of 11, by emodel
I use 1280*1024. Aspect = true in my conf file.
But thats not the point, i would just like an option to specify the screen (window) ratio. Things like 8:7, or 5:4 etc
Im almost sure that would be pretty easy to implement.
Anyway, thanks for the help.
Reply 10 of 11, by Markus
I can't see the point, 8:7 and 5:4 will turn perfect circles into egg-like schemes.
But if you desperately need it, download the source and do it.
Reply 11 of 11, by Elwood
I realize this thread is rather old, and the same points are discussed in other threads as well. I'm having the same problem as well, using a LCD display with 1280x1024 native resolution and 5:4 ratio - would really love to get the games up and running using that ratio and resolution.
What I'd like to do, is:
a) Run a game in a maximized window that exactly fits my screen - right shape or not (i.e. manually set the size of the window to NxM points)
b) Run the game fullscreen, again, stretched to fit my oddly shaped screen.
I couldn't notice any difference between ASPECT=TRUE/FALSE. I figured this would be the setting for doing what I'm looking for - should this setting affect the fullscreen mode or only windowed? Are there other requirements for the option to work?
I can't see the point, 8:7 and 5:4 will turn perfect circles into egg-like schemes. But if you desperately need it, download the source and do it.
The difference between the oldie 4:3 and 5:4 ratio of my current display really does deform shapes a bit, but it is not as bad as one might think without trying it first. In SCUMMVM this thing works really nicely. In my opinion the slight deformation is a lot better option than having those sad black bars on top and bottom of screen.
Sadly, the most challenging thing I can code is a 'Hello world!' -thingie, so I'll have skip the advice on doing anything with them sources. 😉
I hope what I'd want to do is plain here. Did a search on the forum before posting - I guess if such a feature would exist, the other people asking about this would have gotten answers I'd have undestood.
Has this optimizing for weird resolutions/aspect ratios reached the ToDo yet? Like forcing manually the window/fullscreen display to be stretched to NxM pixels or enabling the maximize - button?
* Thanks for the GREAT plaything this DOSBOX is - being able to play them old games is lots of fun with those black top/bottom bars as well! *
