First post, by DarkPenfold
Hi guys.
First up, well done to the DOSBox team for creating such a great program I read about it in the latest issue of PC Zone (UK), decided to give it a go and it works beautifully.
The only problem I'm having in running my favourite PC game ever - Syndicate Plus - is that I can't save it. After not being able to run the game from CD, I copied the contents of the disc to my second hard-drive (F:), in the dosprog folder that the Info file suggested. After some tinkering with CPU cycles, Syndicate runs perfectly from there (full sound, no FPS trouble at all), but won't let me save my game.
I've done a forum search and created "save" directories on the following locations:
F:\dosprog\synd
F:\dosprog\synd\data
F:\dosprog\synd\syndicat
F:\dosprog\synd\syndicat\data
None of these locations work: I'll save, restart the game using the options menu, and then go back to the save/load screen only to find all 8 of the slots are "Empty".
Anyone got this working? If so, could you help me out here? Ta muchly.
