First post, by starwindz777
The great game, Covert Action has only one problem:
"Working at 99.9%. Graphics no longer garbled, but keyboard problems persist. Jump mode is always on, and unless you hold the shift key at the begining of the break-in, your stuck in that mode. Normally, you hold the shift-key down to get into jump mode, and you use the numeric keypad (numlock off) as 8-way directional control. Game works perfect otherwise."
Above description about problem found in game database of dosbox.sf.net.
I hope to this bug fixed soon!!![/b]
