Reply 101 of 141, by Mau1wurf1977
Produced two new videos that show you how to install MS-DOS 6.22 and configure CD-ROM and mouse drivers as well as memory options such as extended or expanded memory.
Downloadable AUTOEXEC.BAT, CONFIG.SYS and CD-ROM and mouse drivers are provided!
Video tutorial: How to install MS-DOS 6.22
MS-DOS CD-ROM, mouse and memory tutorial
My YouTube channel
Reply 102 of 141, by elianda
I got some comments to the second video:
There is only a indirect relation between Turrican II complaining about 'already in V86 mode' and EMS.
Turrican II wants to use protected mode (probably Unreal mode) for it's own memory management.
If you load a memory manager such as EMM386 it switches to protected mode, even if you give NOEMS as option.
(e.g. protected mode is required to map from XMS memory to UMBs.)
Of course on a 386 or better you can use such a memory manager to emulate EMS. However you could also have EMS by plugging a EMS memory card and this would leave the CPU in Real Mode.
Hmm, for the length of the video it's probably accurate enough.
You should note that the CD-ROM driver recommendation is for ATAPI drives only.
Youtube Channel
Reply 103 of 141, by Mau1wurf1977
Thanks for the info 😀
I guess I like to keep my videos reasonable simple. You know, getting people from watching the video to playing old games on their retro PC ASAP 😊
Hmm not sure if I will ever cover SCSI gear...
My YouTube channel
Reply 104 of 141, by Holering
Great stuff! Haven't looked at any your stuff but I personally think it's great that someone gets so much use out of older hardware and software. A lot of it goes to waste and people just push forward and literally throw away the old games and hardware. It's certainly great how you help other people who are interested in the same thing! Very nice. Good stuff!
Reply 106 of 141, by Mau1wurf1977
Website updates!
Added more content to the website:
Doom shareware download
Quake shareware download
Quake III Arena demo download
Incoming and Expendable demo download
Turrican II AWE64 Gold recordings
http://www.philscomputerlab.com/game-demos.html
My YouTube channel
Reply 108 of 141, by Firtasik
What a waste of time! Disk/partition cloning is the way to go. 😎
11 1 111 11 1 1 1 1 1 11 1 1 111 1 111 1 1 1 1 111
Reply 109 of 141, by Mau1wurf1977
Of course. But I never start off with an image. Always a fresh install. Then I take an image. Especially on different hardware.
What cloning software do you use? And do you clone on the retro machine or remove the HDD and clone on a modern desktop (that's what I do).
But I might want to use something that's based on two hard drives. Clone on the retro PC and save the image to the second hard drive. It should also work on older machines with little memory.
My YouTube channel
Reply 110 of 141, by Firtasik
I use Clonezilla Live on all of my PCs. I don't remove disks for cloning, I just save system partition images onto another partitions. 😀
Reply 111 of 141, by Mau1wurf1977
What's the slowest / most basic machine you used this on?
My YouTube channel
Reply 112 of 141, by Firtasik
Athlon XP 2000+, 1 GB RAM. Above minimum system requirements. 😉
Reply 113 of 141, by Mau1wurf1977
Thanks for that! I checked the website and it seems it needs 200 MB Ram minimum. This should work well for my Slot 1 and Socket 370 projects.
Could you please give me a brief summary of steps?
Do you create 2 or partitions?
Install Windows and everything on the first.
Boot with the live CD and image the first partition and save that image on the second?
And then restore partition 1 from the image file that is on partition 2?
How not to mess up the boot sector?
My YouTube channel
Reply 114 of 141, by keropi
awesome!
I use setup.inf as well , it does many things during installation - custom installation, deletes OE, regwizard, useless apps, icons, kills active desktop, setups folder views, installs tweak ui, some updates, IE6.1 , utils, SP2, setups network/autologon... it's REALLY handy and saves lots of time in installations!
Reply 115 of 141, by Firtasik
Methods tested by me:
1. Cloning a system partition with Windows 98
Steps:
- English
- Don't touch keymap
- Start Clonezilla
- device-image
- local_dev -> Press Enter
- Choose /home/partimag - where you want to save the image (probably sda2)
- Directory - may be top one -> Press Enter
- Expert
- saveparts
- Choose the name
- Mark the system partition (probably sda1)
- q2
- -c -j2 (you can also mark -rm-win-swap-hib (for smaller size) and -gm or -gs (for checksums))
- Compression: z0 - fastest, but no compression; -z5 smaller image, but slow; you can try -z1 gzip
- image size (split) may stay 2000
- you can choose -fsck-src-part for a FAT partition
- Yes, check the saved image (if you marked -gm or -gs)
- Choose original to backup (it may not appear)
- Choose Reboot
2. Restoring a system partition with Windows 98
Steps:
- English
- Start Clonezilla
- device-image
- Choose /home/partimag - where you saved the image (probably sda2)
- Choose a directory (may be top one)
- Expert
- restorparts
- Choose the image
- Choose the system partition (probably sda1)
- Mark: -e1 -e2 -c -t -r -j2 -cm or cs (if you made checksums)
- k - Do NOT create a partition table on the target disk
- y & y
- Choose Reboot
You can install Windows on a virtual machine and test it there first. 😀
Reply 117 of 141, by Firtasik
You can use that P100 HDD on a modern computer (parallel xz compression FTW!), for example, through a IDE to USB adapter. Clonning/restoring this way a fully configured system is still a time-saver. 😀
Reply 118 of 141, by Mau1wurf1977
I've been doing this for like forever 😀 I swear it booted for 10 minutes before I gave up and restarted the Pentium. On the USB 3 CF card reader the image took like 15 seconds.
My YouTube channel
