First post, by c_t_f
- Newbie
I used to have a CD copy of Treasure Cove AGES go, which had the soundtrack available as MIDI files. I've long since lost the disc, but found a floppy version much later.
I've tried finding the MIDI files on the disc and in the installed files, but as far as I can tell the files aren't as "available" as they were with the CD version. Is there a way I can extract them?
Necro edit (in case anyone stumbles here via Google or something): You can't extract midi files from the DOS version. In the Windows version, the midi files are located right on the installation disk and can easily be extracted.
@CTF@
