First post, by jpt9
I have a feature request that I'm sure everyone wants -- the ability to execute a config.sys and autoexec.bat file on DOSbox startup. Or at least the ability to set FILES = x in the configuration file. This feature would probably be extremely useful, considering the many posts about needing to be able to change the number of FILES. E-mail me at jtuttle [at] g*NOSPAM*mail [dot] com. (Convert [at] to "@", [dot] to ".", and remove the "*NOSPAM*".)
Thanks.
-- J.P.
Reply 1 of 7, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
ATOEXEC.BAT functionality does exist - write the commands in DOSBOX.CONF.
You will be able to use CONFIG.SYS when using image support and booting real DOS. This will be in the next version.
Mirek
Reply 2 of 7, by MiniMax
Rank Moderator
Moderator
For what it is worth, I have this in my DOSBox config file.
[autoexec]
# -- Lines in this section will be run at startup.
@echo off
pause
echo Mounting "D:\DB-Games" as drive C.
mount C "D:\DB-Games"
echo Mounting "L:\" as CDRom.
mount G "L:\" -t cdrom -ioctl
C:
if exist "C:\Config.Bat" call Config.Bat
if exist "C:\AutoExec.Bat" call AutoExec.Bat
There is no real need to have both an Config.Bat and an AutoExec.Bat, but it allows me to keep stuff divided just in my real MS-DOS setup.
_________________
Reply 3 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
config.sys support is not needed.
just create one in your virtual drive and put it there.
There is nothing you would have to setup in there. Dosbox has very very sensible internal settings.
But some games check for a physical config.sys on c:\
instead of checking the tables. So create one (which isn't used by dosbox) so the game is satisfied.
Water flows down the stream
Reply 4 of 7, by MiniMax
Rank Moderator
Moderator
Thanks.
-- J.P.
No.
_________________
Reply 5 of 7, by jpt9
I need to be able to set FILES = 30 to run Lotus Agenda. This is pretty much the only thing that I (and a bunch of other people here) would need in CONFIG.SYS.
Reply 6 of 7, by MiniMax
Rank Moderator
Moderator
@jpt9, have you tried creating a dummy CONFIG.SYS in your (DOSBox) C: drive, a dummy file with just 'FILES=30' in it?
_________________
Reply 7 of 7, by jpt9
Just tried -- it doesn't work. I've heard that DOSBox gives programs FILES=100, and that some programs can't handle that much and think there isn't enough. Agenda must be one of those programs. It actually needs the number of files set to (at least) 30, and apparantly some number less than 100. Any help?
-- J.P.
