Long File Name (LFN) support (SDL1)
Here you can discuss the development of patches.
Postby Wengier » 2014-9-03 @ 21:06
DOSBox is a great software which will emulate DOS under various operating systems such as Windows. Unfortunately, the latest official version of DOSBox still lacks Long File Name (LFN) support, which is a very important feature implemented since MS-DOS 7.x and Windows 95. I have seen many DOSBox users requested this feature in the past years in various forums, but no solution was yet given. So I decided to go ahead myself and finally managed to implement LFN support for DOSBox.
LFN support in DOSBox come with two parts, one is LFN support for shell commands such as DIR/CD/COPY (as well as the auto-completion feature of the Tab key), the other is the implementation of Int21/AX=71xx functions for LFN-aware DOS programs. Currently the first part should generally work fine, and for the second part - the great majority of AX=71xx functions have been more or less fully implemented, so many or most LFN-aware DOS programs should already work fine with LFN in DOSBox now, but some functions have not been implemented completely, so problems with certain LFN-aware DOS programs may occur. Besides LFN support, this build uses the actual 8.3 short file names instead of generating arbitrary ones when running under Windows which has the 8.3 file name generation turned on. The initial build is intended to be a "proof of concept", so if you find any issues regarding LFN you can report them so that they may be fixed soon or later.
The current LFN-enabled build, known simply as DOSBox SVN-lfn, is based on the official DOSBox SVN version. I have uploaded the Windows 32-bit binary (along with required run-time files such as SDL.dll) as attachment. The DOSBox source code is quite large so I am not really sure how to upload it. Suggestions are welcome.
(P.S. I originally intended to post this thread in the DOSBox Patches Forum, but found that I could not, so I decided to post it here instead.)
EDIT: It has now been moved to the DOSBox Patches Forum. The attachment remains the same. The Windows binary now also features automatic drive mounting, direct LPT passthrough, APM power off, DBCS and mouse copy/paste support (and the DOS APIs that communicate with the Windows clipboard are supported too; see also the other thread by me in this forum) in addition to LFN support.
EDIT2: Updated the attachment. The latest Windows binary (along with required DLLs, zipped) is always downloadable from the URL: http://bit.ly/12jANWF (or from http://bit.ly/1laDvGX if you want the Windows binary compiled with MinGW instead of Visual Studio)
For more information and download links relating to my LFN-supporting versions of DOSBox and vDos, you can visit the page made by Edward Mendelson (emendelson) here: http://wpdos.org/dosbox-vdos-lfn.html
You do not have the required permissions to view the files attached to this post.
Wengier
Re: Long File Name support
Postby Dominus » 2014-9-03 @ 21:36
If you use SVN "properly" you can just make a diff against it (svn diff > lfn.diff) and post that. Or find some other way to make a diff/patch (I'm not using Windows anymore so I can't really say).
Moving it to the patches forum as well (thread starting is prohibited to keep that forum kind of clean)
User avatar
Dominus
DOSBox Moderator
Postby Wengier » 2014-9-03 @ 23:33
Dominus wrote:If you use SVN "properly" you can just make a diff against it (svn diff > lfn.diff) and post that. Or find some other way to make a diff/patch (I'm not using Windows anymore so I can't really say).
OK, Thanks. I have managed to make a patch.diff file of the source code using the diff command. Please see the attachment.
EDIT1: See later post for latest source patches, or get the updated zip file containing all source files changed from the latest SVN version from the URL: http://bit.ly/1umlc4J
EDIT2: For most recent source diff, please download from Page 5 of this thread.
Wengier
Postby collector » 2014-9-03 @ 23:59
I am not sure what happened to my earlier post, but are there any DOS games that require long file names, let alone can even read them?
User avatar
collector
Postby Wengier » 2014-9-04 @ 00:17
collector wrote:I am not sure what happened to my earlier post, but are there any DOS games that require long file names, let alone can even read them?
Good question! Personally I never played a commercial DOS game that would *require* LFN support myself, but since I am not a real gamer this does not mean there are no such games exist. However, LFN support in DOSBox is at least useful in two different respects. First of all, support for LFN in DOSBox shell commands (DIR, CD, COPY etc) would allow users to work with the more familiar names that are used in their host operating systems, such as Windows or Linux, instead of the truncated "ugly" 8.3 names. But of course they can ALSO work with the 8.3 names, so now users have more choices and they can select from one of them depending on their own preferences instead of forcing them to work with the 8.3 names, which many of them may not actually be very familiar with. Second, even though most (or all) games (or other DOS applications) do not necessarily require LFN, many of such games or applications will SUPPORT and also BENEFIT FROM them. These will be a big plus than the 8.3 only option.
Wengier
Postby ripsaw8080 » 2014-9-04 @ 01:11
LFN support will in most cases not give any benefit to DOS games or applications, and in fact can cause problems because there is an expectation of (or even reliance on) the 8.3 limit. The exception is games or apps developed to work in DOS 7 or the NTVDM where long filenames are used; however, official DOSBox targets DOS 5/6 where the 8.3 limit is inherent.
User avatar
ripsaw8080
DOSBox Author
Postby Wengier » 2014-9-04 @ 01:28
ripsaw8080 wrote:LFN support will in most cases not give any benefit to DOS games or applications, and in fact can cause problems because there is an expectation of (or even reliance on) the 8.3 limit. The exception is games or apps developed to work in DOS 7 or the NTVDM where long filenames are used; however, official DOSBox targets DOS 5/6 where the 8.3 limit is inherent.
I think you are really talking about the implementation of LFN support. A good implementation of LFN will almost never cause any problems to actual DOS games or applications because the games or applications in the first category as you say (i.e. those expect or rely on 8.3 names) will never call the AX=71xx functions, but will instead rely on the usual 8.3 name calls so the returned results will certainly be 8.3 names, and long names will be completely invisible to such games/apps. Only those games or applications in the second category (i.e. LFN-aware games/apps) will support and and then will benefits from LFN features. When LFN support is properly implemented, it will be no harm to any existing programs, either LFN-aware or LFN-unaware programs, in theory at least. On the other hand, it will give extra benefits to LFN-aware programs, which are also the intended effects of such programs.
Wengier
Postby truth_deleted » 2014-9-04 @ 01:49
I believe the official mscdex driver does not support long file names. So, your code would not provide long file names to 95 (or DOS) while accessing CDROM files via the real mode driver.
truth_deleted
Postby Wengier » 2014-9-04 @ 01:53
truth5678 wrote:I believe the official mscdex driver does not support long file names. So, your code would not provide long file names to 95 (or DOS) while accessing CDROM files via the real mode driver.
Thanks for making me aware of this. I will take a look at it. The combination of SHSUCDX and DOSLFN will give LFN support to CDROM files under a real DOS system, so it should be doable for DOSBox as well.
Wengier
Postby ripsaw8080 » 2014-9-04 @ 01:54
Wengier wrote:I think you are really talking about the implementation of LFN support. A good implementation of LFN will almost never cause any problems because the games or applications in the first category (i.e. those expect or rely on 8.3 names) will never call the AX=71xx functions, but will instead rely on the usual 8.3 name calls so the returned results will certainly be 8.3 names, and long names will be completely invisible to such games/apps. Only those games or applications in the second category (i.e. LFN-aware games/apps) will support and and then will benefits from LFN features. When LFN support is properly implemented, it will be no harm to any existing programs, in theory at least. On the other hand, it will give extra benefits to LFN-aware programs, which are also the intended effects of such programs.
Wengier wrote:LFN support in DOSBox come with two parts, one is LFN support for shell commands such as DIR/CD/COPY (as well as the auto-completion feature of the Tab key)
It would seem that your implementation is not good because you've changed the built-in shell. DOS games or apps that use shell commands to get files lists and the like can mess up with long filenames. A good implementation will require loading an alternate shell that is "LFN-aware" (i.e. uses the LFN functions of DOS 7). I suppose another option is some kind of toggle for the built-in shell.
In case you aren't aware, there is a TSR program named DOSLFN that adds LFN support to plain DOS, but I believe it relies on internal DOS structures that are not implemented in DOSBox's internal DOS emulation, and so will probably only work when booting real DOS. There is also a program named Instant File Access that adds LFN support to Windows 3.x, but I think it merely acts as a translation layer between the short names used by DOS and the long names in some kind of table.
User avatar
ripsaw8080
DOSBox Author
Postby Wengier » 2014-9-04 @ 02:08
Thanks for your advice. The current build of LFN-enabled DOSBox will be seen as a "proof of concept" stuff, but it may actually evolve into a full-featured build that will take care all of this. Yes I am indeed aware of DOSLFN, and even had many communications to its author during its development. However, it is written in assembly (instead of C) and will also access disks directly, which is not allowed in recent versions of Windows (besides the fact that DOSLFN will not support NTFS drives obviously). The program named Instant File Access is also as you say not a real Win9x style LFN driver, but merely a translator.
Wengier
Postby ripsaw8080 » 2014-9-04 @ 02:26
You could use setting the reported major DOS version to 7 (VER SET 7) as a toggle for LFN support... just a thought. ;)
User avatar
ripsaw8080
DOSBox Author
Postby Wengier » 2014-9-04 @ 02:39
ripsaw8080 wrote:You could use setting the reported major DOS version to 7 (VER SET 7) as a toggle for LFN support... just a thought. ;)
Thanks for the suggestion. It probably will actually work as this was also what I had done when I added LFN support to Paul Houle's Enhanced DOSKEY (http://paulhoule.com/doskey/) last month. Setting major DOS version to 7 or greater will cause DOSKEY to support quotation marks for Tab completion even if LFN API is not available, since (unlike MS-DOS 6.x or earlier) MS-DOS 7+ will understand quotes even in 8.3 only mode.
Wengier
Postby truth_deleted » 2014-9-04 @ 03:04
I guess another option is to use (external) shell command executables which support LFN and then have a switch to disable the built-in dosbox shell commands where applicable.
truth_deleted
Postby Wengier » 2014-9-04 @ 16:16
truth5678 wrote:I guess another option is to use (external) shell command executables which support LFN and then have a switch to disable the built-in dosbox shell commands where applicable.
I think the implementation of DOS version emulation logic will be simpler to understand and easier to use, but in particular more extensible. This feature will essentially set the major DOS version that the user wants DOSBox to emulate, and the user can change this setting in dosbox.conf. For example, setting the emulated DOS version to 6 or earlier will disable LFN support, whereas setting it to 7 or greater will enable LFN support. This may be extended to certain other DOS version-specific features as well.
Wengier
Postby Wengier » 2014-10-22 @ 20:36
I was working on some other projects recently, but now I decided to update DOSBox LFN build once again after discussions with some other DOSBox users who are interested in this feature on other forums. By now I have already added the ability to turn LFN support on or off to the DOSBox LFN version. There is now a directive or command called "lfn" in dosbox.conf (see its [dos] section), which can be set to either true, false, or auto. When setting to "auto", LFN support will be enabled if and only if the major DOS version to report is set to at least 7 in dosbox.conf (e.g. by setting ver=7 in the file, which is now the default by the way), as suggested by ripsaw8080 earlier in this thread. But if you set lfn=true or lfn=false in dosbox.conf, then LFN support will be enabled or disabled regardless of what the major DOS version is set to be. Besides this feature, it will now also use the actual Windows SFNs instead of generating random SFNs by itself on Windows platforms (the latter approach is used by probably all original versions of DOSBox).
Regarding ISO image support also mentioned earlier, it should now support LFNs on RockRidge CDs, but not yet LFNs on Joliet CDs, since I have not been able to find some detailed information for this particular format.
I have attached the binary of this build (along with all required DLLs, zipped).
Wengier
Postby truth_deleted » 2014-10-22 @ 23:53
Is the source code patch available? Interested in testing under dosbox/95: http://support.microsoft.com/kb/152200.
truth_deleted
Postby Wengier » 2014-10-23 @ 16:46
truth5678 wrote:Is the source code patch available? Interested in testing under dosbox/95: http://support.microsoft.com/kb/152200.
Sure, the source code patch is available. See attachment. Yes, I want to implement support for other CD formats too, but I was not yet able to find detailed information about the Volume Descriptor for Joliet CDs for example. It would be great if someone provides such information.
Wengier
Postby Wengier » 2014-10-23 @ 16:47
Furthermore, I have implemented mouse copy/paste support to DOSBox yesterday (not included in the above binary). Should I start a new thread for this feature?
Wengier
Postby Dominus » 2014-10-23 @ 17:03
Yes, please. Post it to the development forum, I'll move it to patches then.
User avatar
Dominus
DOSBox Moderator
Next
Return to DOSBox Patches
Who is online
Users browsing this forum: No registered users and 2 guests
