First post, by viktorcech
Hello, im looking for manual for this MB.. it is good MB?
http://stason.org/TULARC/pc/motherboards/G/GI … ml#.VAhq9RYcJ_9
Reply 1 of 4, by feipoa
There is quite a bit of information on this board already in the forum. Use google to search this forum. Attached is the manual.
    Gigabyte-GA-486AM.pdf
    233.54 KiB
    149 downloads
Reply 4 of 4, by kixs
Can someone with this motherboard check the RN jumper label - the 8 legged jumper that sets the CPU.
This is from my motherboard that has only one of these jumpers. It is labeled 8B000J. Usually the MB has two of these jumpers and I'm asking if they are the same - 8B000J?
Here can be seen that usually two of these are needed to set up an AMD and Intel cpu.
